928 Forum 1978-1995
Sponsored by: 928 Specialists
butcher job
Old 03-30-2017, 05:21 PM
upstate bob
upstate bob's Avatar
Default butcher job
Has anyone attempted to modify the instrument panel to make it easy to service? I'm not concerned with keeping it original but don't want ugly either.
Old 03-30-2017, 05:34 PM
Adamant1971
Adamant1971's Avatar
Received 1,149 Likes on 538 Posts
Why? Once you have done and R&R on it it won't get opened again for a long long time.
Old 03-30-2017, 05:40 PM
77tony
77tony's Avatar
What year ? T
Old 03-30-2017, 05:43 PM
davek9
davek9's Avatar
That was my first thought too
And it's not all that difficult to remove, now if it were a heater core...
Old 03-30-2017, 05:46 PM
M. Requin
M. Requin's Avatar
I think it's only difficult because it isn't done often enough by most to develop a routine. But there is a thread about 15 minute pod removal, and once it's out the instrument assembly itself is pretty straightforward to get into. One thing that caused me a heck of a lot of grief in the beginning was that the PO had mis-routed the cables to the pod switches. Until I found a couple of good photos here on RL I really struggled with that.
Old 03-30-2017, 05:48 PM
M. Requin
M. Requin's Avatar
Ha! Adam, you're generally right, but it was different for me because I kept screwing around with the lighting, and getting my final solution - EL backlight dials - the way I wanted them. And now I need to go in again because in my latest update I re-placed some of the needles incorrectly...
Old 03-30-2017, 05:57 PM
Adamant1971
Doh!
But I bet you will be faster this time around.
Old 03-30-2017, 08:12 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,230 Likes on 1,258 Posts
+1
I was shocked how easy it was to take off the pod, disassemble the gauge cluster and fix the gear. That arrangement lasted 37 years so in theory I shouldn't have to remove it for another 30+.
Old 03-30-2017, 08:30 PM
Weissach
Weissach's Avatar
I think people forget how old these cars are. An 87 S4 is 30 years old. If it's made it this far, trust me---- I don't see much improvement by modifying
Old 03-30-2017, 10:05 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Is once every 30 years too often?
Old 03-30-2017, 11:30 PM
upstate bob
Sorry, I omitted it is a 79. Yeah, the old girl is a bit dim at night. I rarely drive anything after dark but I would like to have it right. Just have to have at it and gitterdone, eh?
Old 03-31-2017, 05:23 PM
karl ruiter
karl ruiter's Avatar
There are some tricks that make it pretty easy. The biggest one is that you don't have to pull the switches out of the pod. Pull the wheel, and the turn signal switches, pull the under covers and the two main fastners. Now you can just tease the gauge cluster out of the grommets where it mounts to the pod and flop the pod forward leaving the cluster in place. Likewise when re-installing you put the cluster in place and connect all the wires. Now flip the pod back into position, tease the cluster into the grommets and install hardware. Easy.
Old 03-31-2017, 05:35 PM
The Forgotten On
The Forgotten On's Avatar
Is the rheostat under the pod corroded? That has caused more than a few people to have dim lights.
Old 03-31-2017, 06:23 PM
Petza914
Petza914's Avatar
Received 6,763 Likes on 4,303 Posts
I believe you can connect together the two wires that go to the rheostat, bypassing it completely, which will give you full brightness for troubleshooting purposes and let you know if you have a rheostat issue or something else.
Old 03-31-2017, 10:04 PM
vanster
vanster's Avatar
I replaced the bolts with allen bolts so I could get a long thin allen wrench into it. Really helps
Next for me is replacing my dash....woo whoo
Quick Reply: butcher job
