Front tow hook
#46
I didn't think you should connect to the control arms, but maybe I'm incorrect.
Regarding the tow hook, have you looked into steel inserts if the threads are messed up as you describe, might be able to recover the use of the tow hook.
https://www.ezlok.com/inserts-for-me...readed-inserts
No affiliation, there are other inserts available. Just a thought.
#47
Basic Sponsor
The sizing is based on supplying lots of hooks over the last 15 years. If we supplied an early style for an 84, 85 or 86 and it did not fit I am pretty sure the customer would have let us know.
Happy to be educated.
#50
tap and drill for tow hook
Does anybody have the specs for the drill and tap? @CraigL And just to confirm this tap is for the larger thread version tow hook?
Borrowed tow eye tap and drill from CraigL.
Proceeded gently with instructions collected in threads. Kept tap and drill lubricated with WD-40. Alternated between brief drilling to remove aluminum debris and 1/4 turn with tap to remove aluminum in threads.
Mission complete; pictures below. Shipping tap and drill back to CraigL this coming Monday.
Tap and drill borrowed from CraigL
/r
Mace
1990 GT black on black
/r
Mace
