Engine coolant volume - how much?
Reading the owners manual it says the engine coolant volume is about 16 liters (4.2 US gallon). Every time I have changed coolant I noticed far less fluid being drained out of the engine and radiator combined. Recently when I did the coolant change on the red car I decided to measure the volume of fluid drained and it was almost exactly 10 liters. I flushed the system with the water hose and let it sit overnight. Next day I replaced the fluid, this time with distilled water mixed with ethylene glycol 50/50 and 10 liters went in.
The question is where does the remaining 6 liter of coolant fluid hide or is the statement in the owners manual incorrect?
Åke
Åke
Received 1,542 Likes
There's 2 - 3 liter of 'air bubbles' until you heat-cycle the engine after a coolant change.
It takes me ~3.5 gallons (~13 liter) for a coolant change. Assuming I don't spill any.
There's about a liter left in the block, heater core, etc.
Edit: Must be more left in the block and hoses.
Team Owner
if you also drain the block then you should be very close to adding 4 gallons = 2 coolant and 2 distilled water
NOTE the block holds about 1.1 gallons on each side,
total 2.2 gal approx.
The heater was set in hot position. I have had the engine through a heat cycle and the level dropped by about half an inch. Less than a liter went in to get the fluid level right. Still I am way off from 16 liter of volume as well as you guys. I have had 928 cars since 1986 (three car since 2000) and as far I recall I have never been able to use 16 liters when filling up the coolant system.
Åke
It may also depend upon how long you let them drip. The radiator will continue to drip,drip,drip for what seems like weeks LoL.
Team Owner
are you running the engine with the heater turned on?
that will use about 1/2 gallon to fill the heater core.
if you cant put in the amount then you have a plugged block or radiator core or heater core or all three
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
This is probably a dumb set of questions but related to this topic.
I have an engine block full of water right now and no antifreeze. I poured a whole gallon of Zerex G05 into my lower radiator hose, split with my reservoir bottle, including an entire 12oz bottle of Water Wetter. How much more straight antifreeze should I add? What is the fluid capacity of the engine block for coolant?
Whether or not the stuff you have in there already allows this volume to be added no so clear-To date you have added 1.1 x2 water plus 1 gallon anti freeze plus the water wetter. This is 12.2 litres- if the fill volume is 13 litres you do not have enough room.
Team Owner
its safe to buy 2 gallons of coolant and 2 gallons of distilled water,
pour half of 1 gallon of coolant into the engine,
then pour 1/2 a gallon of distilled water into the gallon of coolant, mix.
then add the other gallon of coolant and other 1 1/2 of water to the engine,
this will leave you with 1 gallon jug with 50/50 coolant remaining
When the engine and radiator go back into the bay after on-stand assembly of the engine, it takes 4 gallons. There's a significant volume of coolant left even after pulling the drain plugs and letting them drain.
Åke
A number of years ago I changed coolant in the blue car. According to my notes 11 liters went in. It is now time to do the coolant on the blue car again. I will thoroughly measure the volumes drained and filled. Maybe I shall remove the radiator to make sure it is all drained.
Åke
The comments about what's left in the rad, heater core, etc, explain the difference between the system capacity of >4 gallons and the observed change volume of ~3.5-3.75 gallons.
I "drained" my radiator last winter while doing the TB. Pulled the plug and let it drain for a while. Pulled the hoses & let them drain too. After a few days, I pulled the radiator out (for working room) and set it aside.
The next day, there was a pretty big puddle on the floor by the lower hose outlet.
Just to see (and to get all the old coolant out because I was replacing), I put a block under the other end and tilted it toward the hose outlets (toward the back of the car if installed) to get the hose outlet to the lowest possible spot. Also put a pan under the outlet to minimize the mess. I was a bit surprised at how much accumulated.
Maybe half a liter total (including the puddle).
Åke,
Drained my engine jackets down today and managed to avoid the usual ethylene glycol shower one usually gets working under axle stands! Put the caught coolant into a 5 gallon container and reckon the total caught was about 3.5 gallons [13 litres +/-] so I should be OK with the 4 gallons I have ready to put back in.
Rgds
Fred
Rgds
Fred
