Someone needs to 3d print tail lights!
I took out the original tail lights from my 91 and realized just how bad they are. The reverse clear section is popping out away from the red portion. The other lense has a crack. Since they are nla(at least that's what I've heard) , we need someone to come up with a decent replacement. Possibly led instead of regular bulbs.
Archive Gatekeeper
They're about $850 a pair and still readily available, new. Not sure what a printed set would go but the backside of the housing is a really complex shape, as would be the inner surface of the lens.
I didn't know they were still available. My fault! I'm sure it is expensive to 3D the back portion. The leanses prob more to make correctly.
As an alternative, I don't think a 3D printed version has to be as complex as oem if you were using led panels/strips to replace the bulbs.
Cottage Industry Sponsor
Since there would not be big enough of a market to create injection molds, and it's difficult to make silicon molds in this size, 3D Printing would make sense for customized versions of the tail lights.
But I do think this has to be well thought through and carefully designed - otherwise it would look cheap and tacky...
Resin printers like the Objet and Formlabs can print clear pretty well out of the box. But to achieve acrylic like transparency a lot of polishing is needed.
I agree that casting these would be the best route and that would be my approach. I'd 3D print the sections where the it makes sense.
I'll look into this further. At over $800 a set that leaves some room to do better.
Probably would be best/cheapest to develop the lens and then remove the old lens and reuse the housing.
Go for it, but I wouldnt wait for it.
