Crank Bearing Housing Dimensions
Hi All,
I have a block with my machine shop and have given them a binder with all the needed specs to do the rebuild. But I can not find the main bearing journal housing dimensions in the WSM. (dimensions of the housing without the bearing). 89 S4
I know the factory method is to use plasitguage to confirm the bearing to crank clearance, but the shop wants to measure everything first including the housing.
Thanks in advance.
Thanks in advance.
Bump,
I just finished looking through the tech bulletins and still can not find this info. I seem to remember reading a thread about measuring the housing diameters. My machine shop fellow is super **** with specs, which is a good thing.
I have the info now which is great. But I still can't find it in the WSM, does anyone know which section and page # it's on.
Thanks in advance.
Thanks in advance.
Ok I think I finally found it all, plus the tech bulletin for the revised thrust bearing.
