Red Car rebuild
Chronic Tool Dropper
Big steps towards a second life! Looking forward to seeing it in its full glory again.
We discovered water that had been sitting in #5 and the coating was destroyed. The only fix is to bore it and replace with 968 pistons or find another stock block. However we are into this .... and you know what that means....new rods, GB designed crank etc. Since we are into this in such a big way...why not? With luck we could get some serious hp as the engine would then be 6.4 liter. This would really make it a special car while keeping as original as possible.
6.4 liter, should be fun.
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
George
For purposes of personal education, what coating are we referring to here? I am under the impression the cylinders are solid alloy with the silicon particles in solution that form the bearing surface when prepared correctly. Has the base alloy been corroded by water that was sat there [presumably from the fire fighting efforts]?
Rgds
Fred
Fred,
You are correct. We let the water sit in the block ( water from the fire dept) long enough to corrode the cylinder wall enough that the only way to remove it is to bore the hole. The reason we let it sit so long as we were dealing with insurance and the question comes up, do we start the rebuild or do we wait?
Archive Gatekeeper
S3 block= thicker cylinder towers = room for more corrosion = bigger bore = 106 x 95.25 x 8 = 6724 cc = Van in 1st place.
Let it sit a while longer.
No one can accuse you of being a "Fair Weather" sailor! Like Rob says one can always find a "silver lining" if one tries hard enough. When I crashed my motorcycle and got all banged up whilst at University first thing I said to my Dad when he saw me in the accident room was " I am going to get another bike just as soon as I have the insurance money". I was less brave with my nearest and dearest 13 years ago when I was banged up with a fractured L1 vertebra after losing my late S4 due to some plonker on a mobile phone clipping me [Pit style] in a tight bend as I was passing him but she came round after a day or two.
Nothing that GB cannot make better than original. More photo's as you progress- please!
Fred
