Best way to remove mildew/mold from interior surfaces
What products do you guys use?
The Leatherique guy here in Ontario recommended I use Pinesol cleaner. I used the citrus flavor, diluted (but can't remember the ratio) with water. This was aimed at cleaning and killing the spotty whitish mildew that was on my leather seats. I used it generously, being sure to get into the perforations and seams, scrubbed with a toothbrush, then wiped all off. Rinsed with wet rag again, then dried with a towel and let finish drying in the sun.
With the Leatherique applied, and car stored in a dry garage, no more mildew, and the stains are gone. |
Mild solution of chlorine bleach in warm water. Wipe it down, let dry, then wipe it down again. Fresh dry air circulation. If you can get one of those small carpet brush tools use some bleach in that to do the carpet(unless you replace it). You'll need to wipe all surfaces to get it right. Lot of hand work involved.
Originally Posted by docmirror
(Post 13897786)
Hey Guys,
Having spent over 20 years in the commercial and institutional cleaning and restoration industry distribution channel, I have found either Benefect or Concrobium to be the best mold remediation products. After a flood most insurance companies up here in Canada require either of these 2 products to kill and deter mold growth. Concrobium can be had at Home depot and is used under another name in the Boating world. no affiliation with either and just trying to offer up some help. Sonny |
In Houston with cars that have had flood damage or water inside the car. One of the best products that is used with success is Obenaufs Oil.
