928 Forum 1978-1995
Sponsored by: 928 Specialists
What is this on the engine?
Old 12-21-2016, 08:35 PM
Blagave
Blagave's Avatar
Default What is this on the engine?
Can someone tell me what these 3 items are and what they connect to on my 1984 928s euro 16 valve engine. All are located on passenger side.
1st picture is what looks like a air /vacuum valve. Would like to know what it is for and where to connect.
2nd pic. is the tube, would like to know where it suppose to connect too.
3rd pic. Is not very good. There is a steel line that has been capped beneath the tube in question on 2nd pic. Again would like to know what it is and what it connects to.
Appreciate any help.
Old 12-21-2016, 08:51 PM
James Bailey
James Bailey's Avatar
Part of smog and federalzation......car should NOT pass smog test
Old 12-21-2016, 09:02 PM
Blagave
Blagave's Avatar
That is actually somewhat good news. I am going to try and get the car legit for CA. Any idea what it connects to?
Old 12-21-2016, 09:09 PM
Ducman82
Ducman82's Avatar
Tube should be connected to the air pump via a hose. Should be a valve on the other end of that tube that connects to a one way valve to object Air in to the heads, other end goes to the air box
Old 12-21-2016, 09:25 PM
Blagave
Blagave's Avatar
Thank you
Old 12-21-2016, 10:06 PM
Ducman82
Ducman82's Avatar
end of that pipe is number 21
Old 12-21-2016, 10:09 PM
Blagave
Blagave's Avatar
Fantastic......thank you very much.
Looks like I need to source a few more missing parts
Old 12-21-2016, 10:12 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
first picture is the pressure switch for the cooling system,
it goes inline with the vent from the water bridge its connected next to the washer tube inlet
Old 12-21-2016, 10:24 PM
Blagave
Blagave's Avatar
Thank you Mrmerlin.
I started another thread asking about some washer hoses.
It just so happens there is a hard plastic line broken right around the pressure switch. The line runs to the front and connects the the plastic bottle in front of radiator. Is this the line you are talking about?
Old 12-22-2016, 12:20 AM
danglerb
danglerb's Avatar
What is your plan for getting this car through Calif smog inspection?
I think it can be done, but not very easily, maybe swapping in a complete USA engine and smog for the year, getting the BAR cert and reg, then swapping the Euro back in. Which is I think technically illegal, but way cheaper than the full epa federalization and inspection.
Old 12-22-2016, 12:35 AM
Blagave
Blagave's Avatar
Currently working with someone who has gone through the CA system before, will see how it goes.
Old 12-22-2016, 08:27 AM
85euro928
85euro928's Avatar
I may have some of the parts you need. I'll check to see what I kept and pm you, if you're interested.
Old 12-22-2016, 10:49 AM
Blagave
Blagave's Avatar
That would be great. Thanks
Old 12-22-2016, 10:59 AM
James Bailey
Ok will be interesting to see what California is doing now....good luck.
Old 12-22-2016, 06:03 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
that clear line appears to be for the headlight adjusters and since its cracked it now empty
Quick Reply: What is this on the engine?
