Ultimate High Output Bosch Alternator fits 1985-1995
#91
Basic Site Sponsor
Basic Site Sponsor
PM sent.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#92
Upate from me. :-)
Day to day here in LA, in traffic and on the "parking lot conveyor belts" aka Freeways, i see a constant 14-14.2 while moving. Heat soaked (been kinda cool here), the lowest is 13.6-13.8. WAY better then the low 13's and mid 12's i was seeing with the Delco
#93
Basic Site Sponsor
Basic Site Sponsor
Upate from me. :-)
Who came up with that idea/adapter?
Any idea on how many amps it made, before it got hot? (Old design Delco without exposed windings.....they get really hot.)
#95
Electron Wrangler
Alan
#96
Thanks Alan..ive learned some fun new stuff this week.
Ill be hunting down and exploring voltage drop areas around my car this weekend I think.
Now..can you also see a drop on the ground side too..not just in the '+' current path of a circuit?
Like..from the head of a bolt at a ground point to the '-' post of the battery?
#97
Yes. Before or after the main load, resistive elements are all part of the complete circuit, between '+' and '-'. Example in a simple 12V circuit .... 20 ohm load, with 5 ohm resistance before, and 5 ohm after ... '+' to load would measure 2V, across load 8V, and from load to '-' 2V. Every single resistive element (e.g: poor connection or low rated cable) in a circuit will have a measurable voltage drop across it, no matter where it is in the circuit.
#98
Electron Wrangler
Exactly what Dave said!
And note that all conductors (esp small wires) have intrinsic resistance per length, so even before any contact degradation etc there are always some series resistances to the loads - they are just small.
Alan
Alan
#99
What is the story on that Delco alternator? It appeared to have some sort of an adapter bracket to be able to mount it onto the stock 928 bracket.
I will have to dig in to some emails, but someone on here with machining skills made that adapter. i want to say it was an 108 amp Delco off of an mid 80's V6 camaro. It worked, but heat was not its friend.
#100
Dave
#101
Basic Site Sponsor
Basic Site Sponsor
That Delco alternator, like our original Bosch alternstor, has one fan, which draws air through the back, flowing through the interior, and out the front. The "current generation" coils are externally surrounded by the aluminum housing.
When there is a rear plastic cover, like on the stock alternator, the cooling air comes from a remote, cooler, location....which helps some. With that Delco unit, the cooling air comes from behind the alternator, which is pretty hot, in our application.
It had to get very hot, which explains why you lost so much efficiency as the engine got hot.
Never alternator designs (like I used for my upgraded alternator) have two fans, with the "current generation coils" exposed through vent holes in the aluminum, to cool them down much more efficiently.
Pretty cool!
#102
Basic Site Sponsor
Basic Site Sponsor
Basic Sponsor
marine bilge blower
#104
I tried a couple of blowers before I found a quiet one. This is what I used:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'm sure Roger's is great too.
Dave
Dave
#105
I don't think anyone has any "serious concern"....just general interest in how the free wheel pulley works and what affect it has under quickly decreasing engine speeds.
When I started this project, some two years ago, I considered many different alternators for my starting point. While some may have fit easier, they didn't "make the cut" in terms of the performance and reliability I was looking for.
The alternator I picked to use comes from a later model 911 (and variants), which all have a hellish engine compartment temperature and high rpm potential (the 911 and 911 variant application has a slightly larger drive pulley size than our 928.)
Frankly, if the alternator can work in a 911 engine compartment (which has temperatures several hundreds of degrees higher than we will ever see in our location) and can survive the rpms of a 911 engine, my intended application was a "walk in the park" for this alternator.
As an added bonus, its made from all brand new components (not rebuilt), completely designed by Bosch (legendary reliability and performance, not "tweaked" by some alternator rebuilder with his own "backyard theory" on how to make more power), has twin internal cooling fans, exposed coils, has this great one way clutch (which significantly reduces belt heat and wear), and was close to what I needed to fit in the 928 location.
This seemed like the perfect starting point for what I was trying to make.....all I needed to do was make it fit.
Here it is....I think it is beautiful....and it works like a dream, in the 928 application.
Unbelievable how tough these alternators are...30 years for mine??? No american car would ever have an alternator last that long...
