Transmission series number decoder document
Does someone have the document that breaks down the series numbers on the transaxle for the different model years. It shows if the models was manual or automatic, geographic region (USA, ROW, etc) and then offers the breakdown on the limited slip or standard differential.
I remember seeing a Porsche resource document not too long ago, but now I cannot find it. It had very detailed information. I would like to help a friend identify if his gearbox has a limited slip. Here is his trans serial code for his 1982 Euro model: G28/05 11C 0685
I did a little research and found this resource: https://www.928gt.com/t-928trans.aspx. But it doesn't give details on the limited slip.
Any help is appreciated.
Support the rear of the car on stands, release the parking brake and turn one wheel by hand. If the opposite wheel rotates the same direction the differential is a limited slip unit. If the opposite wheel rotates the other direction the differential is a standard open type.
Mike
Mike
Basic Site Sponsor
Basic Site Sponsor
"11" is a non-limited slip.
"12" is a limited slip.
The "C" designates the year.
The "0685" is the serial number.
All of this information is in the Workshop Manual or a pocket spec book.
Archive Gatekeeper
A28 transmission operation book, page 3:
80-84 specs book with similar info, plus some S/N ranges:
Thanks everyone for the info. I feel a little like a knucklehead for not remembering to look in the tech spec. Thanks again!
