Reattaching the battery box cover
The PO of our Blue 87 S4 detached the battery box cover and the spare tire mounting stud (likely for his subwoofer he deleted before the sale)
Anyhow, I would like to reattach the cover. Anybody have some suggestions for how to remove the remnants from the hinges?
Kevin,
Sounds as though you need a Dremel to get rid of the old bits- not sure how you would re-attach a new hinge- probably one of those brss things you get at your local hardware store and some pop rivets.
At least you do not have the problem I had many years ago when the cover welded itself to the positive post of the battery because ******** here forgot to fasten down the battery!
Regards
Fred
Regards
Fred
The pins are rusted. Punch was ineffective.
Team Owner
if possible soak the parts in PB blaster it will dissolve the corrosion,
but it may take a few hours.
I put a rusted bolt in a cap from a spray can and added some PB,
then let it soak,
a few hours later the rusty bolt looked new,
and the rust was gone,
the PB had turned a milky orange
then let it soak,
Me, I'd drill the three spot welds out on the lid and trunk portion of the hinge, get a hold of Mark at 928 International and have him send me a better used set, drill out the three spot welds on the new set...if not already done for removal at 928 int...then clamp the hinge to the lid (aligning holes) and weld each hole closed, then repeat welding technique on trunk portion of hinge. After it cools off, hit it with some paint.
*REMOVE BATTERY FROM CAR FIRST. WELDING SO CLOSE TO THE BATTERY CAN BE DANGEROUS.
If you don't have access to a welder, pop rivets would do the trick.
Brian.
Brian.
Electron Wrangler
Brian.
Brian.
Chemical assistance will do most of it - bit of mechanical help after that, and I'll bet you can get spring fit pins to replace those hinge pins.
However I do think you need the spare bolted down and for the spare mount you will certainly need to weld it in.
Alan
