need help with installing 18" rims on my 1984
Here's a thread about this very problem and links to a couple of posts within that have good pix:
https://rennlist.com/forums/928-foru...-in-wheel.html
Lug nut broke off in wheel!
https://rennlist.com/forums/928-foru...l#post11139119
https://rennlist.com/forums/928-foru...l#post11276544
Looks sharp.
How much clearance do you have between the tire and the fender lip with the new wheels and tires installed? Unless it's more than the width of the spacer, it's going to rub (or not fit at all).
James
James
Sorry about the double post - the site is running so damned SLOW today. I hit "reply" a second time after nothing happened the first time...
James
James
Team Owner
to figure out what size spacers you need for the rear ,
measure the outer side of the tire wall where it passes the fender lip .
NOTE measure both sides,
using the smaller of the two numbers ,
subtract 5MM this will be the ideal spacer size
