Modular Crank Pulley
Attached are some renderings of a proposed modular crank pulley. Each of the three primary sections are separate, allowing for quick-changing the external multi-rib pulley section without removing the crank (could be useful for supercharger or auxiliary load applications), as well as using a custom center section to replace the v-belts.
The middle and rear sections are fastened together with M4 screws that also serve the purpose of engaging the casting ribs in the damper - locking them keyed damper to the crank pulley eliminating the potential for the pulley to slip on the bolt, and combat bolt backout issues.
The front section is held with M6 capscrews.
All the sheaves have been redesigned to the proper standard, the factory crank pulley was stamped/spun and does not have the proper sheave dimensions, which does cause belt problems under some loads.
Here is the link to the 3D redering:
http://cloudviewer.spaceclaim.com/b8...5ac0b0195.html
Electron Wrangler
Hans - fantastic, I am very interested in this. Are there any standards for modular pulleys that would allow you to access existing accessory pulleys - or do you need to make all the modules yourself?
I am especially interested in larger diameter alternator pulleys with wider extra ribbed belts. I'd like to increase the alternator ratio by increasing the crank end diameter and decreasing the alternator end diameter (so for friction area: trade diameter (patch length) for effective width ). I think this would be a good solution for many in very hot climates where temperature derated alternator output is a concerning summer issue. More alternator RPMs is the easiest solution - and I don't really like a much higher idle.
I'd also like a different ratio for my vacuum pump (in place of the air pump).
Alan
Alan
Captain Obvious
Super User
Super User
Why the need for the purple bolts? Maybe have on or two as a place holder during assembly. After that, the mid pulley section will hold it.
Hans,
This is cool!
I assume the alternator has a max RPM spec, is that a concern?
This is cool!
Those screws are inexpensive, less than the added mill operations to add similar drive bosses. The heads are used to capture the ribs in the factory damper, and will interlock with the damper and leverage its keyway eliminating any potential for the pulley to rotate independent of the crank.
Alan
Alan
Captain Obvious
Super User
Super User
Uhhh nice!! Thanks for the explanation.
Basic Site Sponsor
Basic Site Sponsor
Dont forget that there are two distinct A/C pulley sizes...and switching them will lead to disaster on some models.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Electron Wrangler
I think that a 10% ratio change is very reasonable for the stock alternator and you can alternatively swap to alternators that have a wider RPM range. My case is a bit special - I'm not really thinking of the stock alternator for this usage (but I do think it could help for that too). It's probably always better to have a bigger crank pulley and the same or only slightly larger alt pulley to ensure no slip anyway if you are going to improve the ratio a bit. Then you can add a freewheel style alt pulley like a Litens OAD pulley for less dynamic (belt) loading.
Alan
Even if that's not the case, given that I seldom have the opportunity to rev the car anywhere near red line, I doubt the life of the alternator would be shortened even if the alternator's max RPM spec would be exceeded with the motor running at 6,500 RPM. Unfortunately, with an automatic transmission and Phoenix traffic, I seldom get the car above 5,000 RPM. So, I think increasing the ratio 10% would give a welcome boost of output at idle with no real effect on the life of the alternator.
Electron Wrangler
Hans - did this idea go anywhere? I'm seriously interested in a modular crank pulley config now. Different size pulley for the air pump (now a vacuum pump for me) and a different ratio & wider belt for the alternator section.
Alan
Alan
Alan,
Yes and no....
I found a shop that was able to turn my supercharger crank pulleys from a single chunk of billet at a reasonable price, so wen that direction for my kit.
However, the first batch of pulleys had an issue, so I had to "scrap" them. They are not usable for my application, but asked the shop to hold onto them so I could repurpose them for a different design. They would be great blanks to machine the modular pulley from. Alternatively, Its easy enough for me to just put in an order for pulleys if there is enough demand.
What kind of setup are you thinking?
Yes and no....
