Stuck Spark Plug Boots
I went to change my spark plug wires this weekend with the new Beru's I got from Roger on sale. Unfortunately, the current spark plug boots are really stuck in the valve cover. I tried pulling on one with a pair of channel locks and busted some of the plastic, so I gave up.
Is there a trick, tool or technique for getting these out. I looked at some internet sites and one suggested injecting WD-40 through the rubber w/ a syringe, but that sounded a little sketchy, and I don't have a syringe.
Any help is much appreciated. My leads have probably been in there for 12 yrs since the last time I changed spark plugs. I'm sure they're original to car.
Thanks,
Steve
'89 S4 Auto
Thanks,
Steve
'89 S4 Auto
I agree with the trick to use something thin to break the seal between the gasket and the cam cover first, then I use a pair of pliers like these - allows you to get a straight pull - worked great when I did my '89 a few months ago.
Chronic Tool Dropper
I have the "universal" plug wire tool listed first above, plus a Genuine Beru tool that's similar, expensive, and works no better. I hadn't thought about using the hose pliers, but will add that to my "great solutions" database. For those playing along at home, Harbor Freight has a set of 3 sizes these pliers, that are way handy. Not as pretty as the Tekton, but likely from the same fried wonton noodle factory.
Hmmm, seems like I heard that before.
Actually mine were part of a 6 piece set of "Oly-Pro" long reach pliers I got at Costco about 10 years ago. I "borrowed" the image of the Tekton branded ones from the interwebs.
The Harbor Freight pliers would work fine - you don't need Snap On to pull plug boots....
Just wanted to thank you for a great tip. My "circle pliers" came from Amazon yesterday and they worked like a champ getting the stuck boots out with no damage. Cost like eight bucks. Now if I could just get that two hrs back when I was trying to pull them by hand and smashing them with channel locks. Thanks!
Steve
Steve
