928 brake discs - which way do grooves go?
I have a slightly tired 85 s2
Brake discs badly worn- I have a nice pair of shiny Sebring replacements. They are a pair but unmarked.
My car has two of the same discs on it ( Ie wrong!)
The Wsm has an incidental photo of the disc showing th e grooves flowing from hub to the rear of the car, but a line drawing showing they should flow from Hub forwards in the direction of travel.
The retailer of my new discs says they should flow back wards, but videos of people doing stuff to their 928s show mostly the grooves flowing forwards but not always!
P
P
When wheel spins forward the inner end of the spiral should lead the outer end. Scoops air from the inside and throws it outward.
From your description the wsm photo sounds correct if you are viewing the top half of the disc
At the bottom of the rotor it might be ejected forwards a bit and at the top of the rotor rearwards a bit.
Thanks guys for all the responses.
The answer does seem to be that the grooves are not relevant - the very clear diagram of airflows is what counts.
The diagram also fits with the strange sketchy drawing in the WSM - on their drawing the grooves go one way, in their photo showing brake pad changing they go the other so even Porsche have caused a bit of confusion. It would have been useful if they had said ignore the grooves!
Many thanks.
Many thanks.
I didn't want to get into the fact that the air being ejected (simplistically to the rear) a the top of the rotor is actually travelling forwards faster than the vehicle at the moment of ejection as well as travelling outwards. I can't even envisage the aerodynamics of what is happening in the wheel well around where the air gets ejected - pretty confused I imagine, hence why Porsche sort of ducted air towards the centre of the rotor from the high presuure zone at the front of the car where the "centrifugal pump" action of the rotor spins it outwards.
Even though the vanes point one way, the air is moving the other way due to the wheel going around. (assuming the rotor is mounted correctly.)
If you just had the rotor and spun it, the air that comes out would be turning about the axis of rotation just like the rotor. The curved vanes increase the effectiveness of the pumping, and improve the stiffness of the rotor, but they don't make the air go "backwards" faster than the rotor is turning forwards.
And... If the orientation of the rotor isn't important then let's all gang up on the next person who asks for the "best" oil, brake fluid, gear lube, steering ATF, washer fluid, tire air, etc. for their street car.
