Timing belt reinstall - Another PK tensioner over extended?
#181
Captain Obvious
Super User
Super User
Yes, yes, I know. That's not what I meant. Porsche made one tensioner of each variation. For example, all tensioners for the '87 are the same. This part works for all the engines that was released for that model year. They didn't have one that worked for most of the '87s, it worked on all of them. That's my point. If the Audi tensioner is supposed to work on all stock 928s but it doesn't then the design parameters of the product are wrong.
#182
But...why? The factory roller hardly ever comes into play (apparently), but if it does, it prevents what it is meant to prevent. It hardly weighs anything.
#183
Captain Obvious
Super User
Super User
Provide me with a phone number, I will speak to the shop in question.
I've rebuilt tons of these racks. I've only had one other have a seal failure which happened a month after the rebuild.
He drove over 20k after the rebuild. The insides of these racks are very simple and there is no way that any pieces were left out. If you leave any pieces out either the rack will not work or it will leak right away. There are no pieces that can be left out allowing the rack to last 20k+ km and then fail.
Regarding the tensioner, ship me his Porkensioner and I will ship you a factory S4 tensioner and arm that you can rebuild.
If you feel the way you do about the tensioner you're only going to cause further problems with the system so it would be best if you are going to work on that car to go with a system you're comfortable working on.
I'll get you the shop's number from Danny and you can discuss the steering rack with them. I'm only replacing it. As for the tensioner, don't worry, I feel perfectly comfortable working with it, regardless if I like it or not and will stay on the car. Now having said that, the one on there has a cadmium finish and the bolts don't look like the one in the black edition. Is it safe to leave it there or does it need to be retrofitted with the updated hardware? I would also Ken, I mean Porken, but he black listed me.
#184
Dave
#185
Remember that the tensioner is a spring, piston and check-valve, so it extends quickly with the spring pressure (more when the rod is compressed, less when extended). However when the rod is compressed (e.g engine kicking backwards) the check-valve is closed and the compression rate is limited by fluid leakage around a tight-fitting piston.
Put a tensioner on the bench, rod-end up, and whack it with a hammer. It won't compress. Stand on it and wait, and it will slowly compress.
The trouble with over-extension, besides the potential for running out of travel, is that the spring force gets weaker the farther out the rod extends. And friction in the lever assembly adds to that.
#186
The PKT hardware kit includes a special flat-head fastener with M8 threads but a 82-deg countersink angle to match the bracket. This is the retrofit for the "gold" bracket.
The "black" bracket is countersunk with a proper 90-deg bit and uses a standard M8 flathead. The other alternative is the one Colin mentioned above, re-drilling the countersink on a gold bracket with a metric 90-deg countersink, and using a standard M8 flathead.
I hope this helps.
#187
Inventor
No, it is not safe to leave it. The problem is that the older "gold" brackets were countersunk with a 5/8" SAE 82-deg countersink bit, while metric M8 flat-head machine screws have a 90-deg angle. The result is that the fastener makes contact only around the edge, which increases the bending moment (which is aggravated by the oversized 9mm thru-hole for an 8mm fastener).
Jim enjoys finding problems that could happen on paper, but don't in the real world. He should try his hand at creating unique 928 products, which I'm sure would be awesome, on paper.
#188
While the 82° countersink is not ideal, it has not proven to be a problem, except in Jim's mind. All flat head bolts have been found to be tight. He knows this. And, the through-hole 'problem' is in fact not a valid issue.
Is anything that I said incorrect? If so, I would be happy to correct it.
#189
Dave
#190
Inventor
#192
Inventor
Truthfully, the special bolts were a 'feel-good' measure. But if it makes you feel good, please accept a hardware update pack, with my compliments, from Roger.
The lever and pulley through bolts are better all around. I would like to change those eventually, myself. The threaded holes to use the bolts which came with the INA parts was again a nod towards an easier installation.
#194
FWIW, I have not changed the ones in my 928 'fleet', which all have gold brackets.
#195
Shameful Thread Killer
However, in this case I have no idea of the potential for it working loose, but in the aircraft world, it would not be allowed.
