PSA: Cam lobes not centered to lifter bore
Administrator - "Tyson"
I don't recall noticing this before.
As you can see in the photos the cam bearing is centered in the housing.
Under the Lift
Yes. Normal with "flat" tappet lifters. Look at your cam lobes and you will also notice they are not perfectly square ended, but have a taper. Both help to reduce lifter and lobe wear.
That was my first thought, the offset keeps the lifter / valve rotating. Then I recalled the controversy of using 944 heads due to the lifter bores / lobes not lining up.....
The lifters are NOT flat, nor are the cam lobes, they have a taper to them.
If the lifter is flat, it's garbage.
This is setup this way to ensure that the lifter keeps rotating resulting in a much longer life of the parts.
Under the Lift
https://rennlist.com/forums/928-foru...ml#post6078221
and this:
https://rennlist.com/forums/928-foru...ml#post6706678
And you were in that thread.
Rainman
it's like an endless supply of "euro" heads if you guys can make 928 cams play nice with the 944 heads.
stock 944 camshaft from 82-85 has the same lift/duration as the 85 928 euro S...and I was able to get 160hp at crank (136 wheel) through a stock 944 head with that mild cam, 9.5 cr, 91 octane and like 32-34* max advance at WOT...so the flow is there...
Captain Obvious
Super User
Super User
The are offset like NASCAR.....made turn left. Check out that cutaway video of a bike head on YouTube. The spring will start visibly rotating when the rpms go past 10K.
