928s for Sale
#2581
Yes Steve, interior is in superb condition as is the rest of the car. Alex particularly likes the way the interior matches one of his fav outfits...(that's him in the middle). Mokka will be at upcoming PVGP if you'd like to have a better look. T
#2582
Former Vendor
#2583
You're letting a car that runs and drives well go for $1,500? WTH? If you were closer to me I'd be there with a check.
#2585
It's was going to the crusher because they couldn't get it to run . Sitting under a pine tree. I cleaned inside , grabbed the a pillars and sunroof cover for my car. I refreshed fuel injector rubber lines and return hose, repaired wiring and sorted out blower , wipers and cleaned some grounds. Drove it to work for 3 days . I just didn't want it to go to crusher but have other projects to finish . I had 2 people come at same time and got 2 k for it. I made small profit and a 928 didn't go to scraper..... I feel better
#2586
1989 928S4 For Sale - 143,100 miles
$13,000
VIN: WP0JB928KS861078
Job change requires me to sell the car that has been my daily driver for the past 6 years. Attached is a mostly complete list of all the parts and items that have been tended to during my ownership. I couldn't bring myself to adding up all the receipts.
The list is extensive and most parts are from our usual suppliers. I have most of the reciepts. Additionally, this forum has most of my adventures documented.
The car was recently professionaly painted and is a 8.5-9.0. There are many little things that have been fixed along the way not included in the parts list: Interior LED upgrade, Seats refurbished and dyed, USB Power plug, Relays replaced, Radiator Fan Fusable Links, Jerry Feather spare cover and hood sill and more.
Known issues I have not got around to or gave up on:
1) A random gieger counter type rattle when idling and turning off car. This has been happening for 3+ years and is a mystery noise that Raleigh area 928ers have not been able to fix.
2) Electric side mirrors not operational since paint job.
3) Cruise control not operational.
I will be listing the car on eBay but wanted to announce to the forum first. Please PM if you have an interest in the car. There are several 928ers in the area than can do an inspection. More pics will go up on eBay.
Parts and Repairs completed.
Description Date
Used Left Rear Caliper(928 Intl) 4/17
4 Wheel Alignment 10/16
AC Recharge 7/16
New Windshield 5/16
Paint job 3/16
AC Condenser test and recondition 6/15
Temp II Sensor 12/11
Additional keys 11/13
Seat Dye materials 2/11
Power Steering line 2/14
Torque Tube and TC Seals 5/12
Delrin Rack Bushings 5/12
Upper & Lower Radiator Hoses 4/11
Steering Rack Boot 4/11
2 CV Boots 4/11
Heater Feeder Hose 4/11
Porkensioner 4/11
PKLamp 4/11
Transmission Mounts 12/11
Transmission reservoir, flare kit and filter service 4/11
Steering Wheel Recover(Budd) 4/11
Arm Rest Support Bracket(driver side) 4/11
Driver side door handle 1/11
Rear Hatch Pin Switch 1/11
HVAC Diaphrams(All 4) 4/13
Laso Plastic Impeller WP 4/17
Continental Timing Belt 4/17
BERU Wire Set 10/11
Spark Plugs 8/11
Zimmerman drilled rotors 9/16
Brake Pads and Wear Sensors 9/16
Rotors and Distributors 10/11
Radiator - Aluminum 928 Intl 2/15
Hood Liner w/decal 4/12
Fuel Line Replacement 928s RUS kit 5/11
Greg Brown U line Fuel Line Replacement 12/16
Motor mounts 4/11
Coolant Tank Fluid Level Sensor 1/12
Window Switches 9/12
AC Climate Head Unit rebuild 6/13
Radiator Cooling Fans(928 Intl) 3/17
Door Sill cover strips and trim 10/14
Door weather seals 11/14
Hood Struts 8/14
HVAC Manifold 8/14
Lower Outer Window Seal kit 4/15
Air Filter 5/15
CV Boots Rear (2) 9/15
Stainless Steel Brake lines 4/17
Various plastic and rubber parts for trim after paint 5/16
Front wheel splash guards and foam seal 3/16
Front main crank seal 3/17
Oil Pump Seal and O ring 3/17
New tensioner mechanism 3/17
A/C Resistor Pack 8/15
Windshield nozzles 8/15
Fuel Pump, filter and strainer 11/13
Dip Stick 11/13
Battery 11/16
Steering Rack(Rebuilt) 8/12
MAF - Rebuild 928sRUs 12/16
$13,000
Description Date
AC Recharge 7/16
New Windshield 5/16
Paint job 3/16
2 CV Boots 4/11
Porkensioner 4/11
PKLamp 4/11
BERU Wire Set 10/11
Spark Plugs 8/11
Motor mounts 4/11
Hood Struts 8/14
HVAC Manifold 8/14
Air Filter 5/15
Dip Stick 11/13
Battery 11/16
#2587
#2588
#2589
A couple nice early OB's on E-bay....
'78 Euro: #9288101003, 5 spd.
http://www.ebay.com/itm/322527636585?ul_noapp=true
#2590
[QUOTE=NC928S4;14216887]1989 928S4 For Sale - 143,100 miles
$13,000
1) A random Geiger counter type rattle when idling and turning off car. This has been happening for 3+ years and is a mystery noise that Raleigh area 928ers have not been able to fix.
Not to be picky, but I fixed it for you. Ask me how I know.
$13,000
#2592
1989 928 S4 White auto $11K in PHX. 164k miles.
Exterior looks very nice. No interior pics. No affiliation.
https://phoenix.craigslist.org/evl/cto/6150379413.html
#2593
1983 928 S Euro. Silver (paint going bad). Burgundy interior, drivers seat shot. Runs, electrical issues. Auto. No affiliation. $7750. In Gilbert AZ
https://phoenix.craigslist.org/evl/cto/6151970089.html
#2594
#2595
This would make a great addition to your collection of 928s.
