high RPM at statrup?
I recently send the car to a mechanic to redo the manifold gasket(First manifold gasket change made a whistle/air gushing sound) & he changed the throttle body seals & clean the throttle body, hose etc etc. Car is fine now & can feel the power etc.
Only thing that's annoys me the high RPM at startup. If I shift to D. The RPM will be normal & if I shift back to P- The RPM will be a bit high.
Sometimes when warm- the car will be OK. (RPM is normal). The mechanic said give the car sometimes & always drive it around. Everything under neat is new like the manifold gasket, clean throttle body & new seals etc. hose under the throttle body is changed.
Remember that when you are in D there is a small load on the transmission that wants to move the car forwards unless you hit the brake pedal, when you put the transmission back into P the load is removed so temporarily the motor tends to speed up a bit but then the ISV should kick in to compensate. Maybe you have a problem with the ISV- I seem to remember you posted something about this a few weeks ago?
Fred
If your idle is fine and shift to park and the idle is high....900 rpm or more then you may have a crack on the vacuum hose connected to the throttle body.
