928 Forum 1978-1995
Sponsored by: 928 Specialists
White "rust" on bolts. How to prevent, or correct?
Old 04-07-2016, 07:26 PM
  #31
crushingday
crushingday's Avatar
Originally Posted by Speedtoys
I would think you would not want to paint over any of them.
Just...clean it.
None of these are films.
A proper cleaning and etching of ANY metal thing before painting would do the jobs.
I did not mean to imply that I was considering painting over them. I have heard stories of using any silicone type chemicals near a surface that may eventually be painted can cause issues with the finish , even if one believes they have cleaned that surface well.
Old 04-07-2016, 07:30 PM
  #32
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
That likely means that they did not clean it well.
Old 04-07-2016, 08:34 PM
  #33
The Deputy
The Deputy's Avatar
Originally Posted by AO
I was very skeptical of this method at first, but one of our local guys swears by it, and then I started doing it, and I must admit, it really works.
A very light coating of WD-40 does a great job of sealing things up and preventing the oxidation from coming back.
Get a can of WD, protect your fenders, and give it a liberal dousing. Spray it everywhere in the engine bay. Then let it soak for a the better part of a day. When you come back, take a rag and wipe it down to gather any excess. re-hit any tough spots or places you might have missed previously. If you do this every year or two, you won't get that oxidation (or less of it).
This is what I do. Granted, usually hit everything under the hood with WD about twice during the off-season. Seems to be working satisfactory.
Brian.
Old 04-07-2016, 09:14 PM
  #34
wpgshark
wpgshark's Avatar
Although a good wipe with acetone should allow reasonable adhesion.
Old 04-07-2016, 09:19 PM
  #35
karl ruiter
karl ruiter's Avatar
I use fluid film for that exact application. Although, in a really tough application (the steel chain in the weather on the gate opener at a house on the beach on windward oahu), even fluid film did not hold up very long. Motor oil REALLY holds up.
Old 04-07-2016, 09:48 PM
  #36
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Silicone kill paint adhesion.
I spent several years of my life fighting that problem on aircraft.
One of our subs used a silicone mold release on large composite panels. Even after extensive, painstaking, cleaning, sanding, washing, et. al., ad nauseum, the paint film would literally blow off in flight...
Old 04-07-2016, 10:10 PM
  #37
wpgshark
wpgshark's Avatar
I recently redyed my leather dash. Prep was cleaning, lacquer thinner moisturizer prep agent dye. I did the whole interior, lots of leather parts. Only failure I had was the center of the dash, contacted leatherique and thy said it was likely caused by silicone residue that survived the lacquer thinner. I've stripped the dash again and will be dying it this spring, hopefully I got it all this time.
Persistent stuff silicone
Old 04-07-2016, 10:24 PM
  #38
SMTCapeCod
SMTCapeCod's Avatar
Originally Posted by GuardsTurbo
Wd40 is good but doesn't last.
WD has an extended protection corrosion inhibitor out now- as Stan mentioned it has a cautionary statement about applying on rubber materials.
Old 04-08-2016, 12:33 AM
  #39
jwyatt8171
jwyatt8171's Avatar
Fluid Film seems to be working good. I bought a small container that includes a brush. Its ugly brown going on, but after the engine bay heats up, and it liquefies it leaves a nice sheen finish and has changed the ugly white rust to darker gray color. The coated gold bits look better as well. I will post updated pics tomorrow.
Quick Reply: White "rust" on bolts. How to prevent, or correct?
