928 Forum 1978-1995
Sponsored by: 928 Specialists
Possible cheap coolant level sensor replacement?
Old 09-30-2016, 11:05 AM
  #121
Jerry Feather
Jerry Feather's Avatar
I stopped by the machinist's on tuesday to check on any possible progress on the new caps, even tho it was before the two weeks predicted, and they said possibly this thursday or friday--today. I am expecting a call from them to come over and see the first one run and to give it my blessing for the full run, which I hope will be done early next week. If I can remember to do so I'll take my camera and take a picture of what they have produced.
Old 09-30-2016, 06:58 PM
  #122
Jerry Feather
Close, but no Cigar, yet. I stopped by the machine shop this afternoon and they were working on converting my drawing to one in their computer for use in the CNC Lathe. It looks like monday before they will have one turned out for me to approve. I was, however, able to explain a couple of things about my drawing.
Old 10-03-2016, 05:41 PM
  #123
Jerry Feather
Here are the first two newly designed Coolant Sensor Caps. They still need to be machined to hex around the top, and I am going to do that myself. I have to make a jig to go in my rotary table in the mill then machine the flats. I might work on that this evening.
Old 10-03-2016, 06:57 PM
  #124
MjRocket
MjRocket's Avatar
This is looking good, coming along nicely.
Old 10-04-2016, 10:10 AM
  #125
Chris Lockhart
Chris Lockhart's Avatar
Looking good so far Jerry.
Old 10-04-2016, 10:50 AM
  #126
Jerry Feather
I have the sealing ring glued to the underside of the top ring on the sender, so this item would function just fine the way it is. As to the flats around the top of the cap, last night it occured to me that I doubt that anyone has ever installed one of the original senders with a huge spanner and even that no one has likely had to use such a tool to remove one of these.
A thought I have previously had is that it might be better with knurling around the top rather than being hex shaped. However knurling on this hard plastic must be cut in rather than rolled in as with softer plastics, or aluminum. Then I woke up last night thinking about cutting the flats on these with the jig that I made yesterday and was dividing the circle into sixes flats, again, and was thinking what it would be like to divide the circle into seven or 8 flats, just for the fun of it.
Then it came to me that the better way to finish the tops of these caps was to divide the circle into several more segments and simply mill rounded slots (verticle grooves) several places around the top to form it in a finger grip fashion rather than hex. I think that is what I am going to do, unless anyone else can convince me that a huge spanner is likely to be needed.
Old 10-04-2016, 11:19 AM
  #127
Jerry Feather
Here are some pictures of the current status. I need to drill some holes in the flat bar to ut it together and mount it in the rotary table and then I can do the milling. I also need to find the correct washer for the top to hold the caps to the jig. I'll have the finished batch of caps tomorrow, I think.
Old 10-04-2016, 01:04 PM
  #128
Shawn Stanford
Shawn Stanford's Avatar
Why not just cut some vertical grooves into the rim of the cap and call it a day?
Old 10-04-2016, 02:05 PM
  #129
Jerry Feather
That's what I tried to say I was going to do; but thanks, Shawn. (Edited it)
Old 10-04-2016, 03:50 PM
  #130
Shawn Stanford
Oh! Sorry, I see that now. That last paragraph didn't register on my brain the first time I read it.
Disregard. Carry on!
Old 10-04-2016, 04:55 PM
  #131
Imo000
Captain Obvious
Super User
Imo000's Avatar
Or just leave them as is.
Old 10-04-2016, 05:18 PM
  #132
DKWalser
DKWalser's Avatar
The fear is that "as is" the smooth plastic doesn't offer enough grip to hand tighten the unit sufficiently for it to seal reliably.
Old 10-04-2016, 05:27 PM
  #133
Imo000
Captain Obvious
Super User
Imo000's Avatar
Then send a surgical glove with it!
Old 10-05-2016, 11:06 AM
  #134
Jerry Feather
I drilled the flat bar and put the jig together then lined it up in the center of my rotary table and cut the flutes in one of these first two caps. I used a 3/8 inch round nose mill cutter and cut the flutes at 30 degree intervals. That resulted in 12 of them, but I think that is a bit too busy. I'm going to cut the next one at 40 degree intervals and see if I like that better. The only problem in that this acetal material cuts leaving plastic fuzz around all of the cuts that has to be trimmed away with a knife.
Old 10-05-2016, 04:36 PM
  #135
DKWalser
DKWalser's Avatar
Jerry -- Re: the plastic fuzz, would it be possible to start the flute cuts from the top of the cal and then complete flute by cutting from the bottom of the cap? I don't know with your equipment if that would be quicker than trimming off the fuzz by hand, but it should get rid of the problem.
Quick Reply: Possible cheap coolant level sensor replacement?
