928 Forum
Sponsored by: 928 Specialists
Possible cheap coolant level sensor replacement?
Old 04-25-2016, 12:54 PM
  #91
ROG100
ROG100's Avatar
Sort of response I expected from you - we tested it electrically but not in a 928 because it would not fit. Just trying to be positive - I would fit one before you make a lot of parts - trial installation and hook it up to a 928 harness and make sure the light works on the dash. Simple stuff. I think it will work but better to prove it first.
ROG100 is offline
Old 04-25-2016, 01:07 PM
  #92
SeanR
Running up the Odo'
SeanR's Avatar
Originally Posted by Jerry Feather View Post
Yeh, I guess you missed it. A couple of guys named ROG100 and Sean tested it and found that it works electrically, but that it will show low level of coolant at a slightly different level, which was no show stopper. Check out posts 38 and 40 above.
The hell sorta response is this? I never plugged it in to a 928, in to a 928 connector and sure didn't test to see if it worked.
Nevermind, Rog addressed it.
SeanR is offline
Old 04-25-2016, 03:59 PM
  #93
Jerry Feather
Jerry Feather's Avatar
Yes, I know. I was just pulling your chains.
Jerry Feather is offline
Old 04-25-2016, 09:59 PM
  #94
ROG100
ROG100's Avatar
I tracked down a better quality part from a more reliable wholesaler. Part comes with the cap but as already defined it does not work however easily removed.
Once we know the part works in anger on a 928 and coupled with Jerry's parts we should have a winner.
New unit (with cap) next to old unit
ROG100 is offline
Old 04-25-2016, 10:29 PM
  #95
Imo000
Captain Obvious
Super User
Imo000's Avatar
Is it going to be accurate?
Imo000 is offline
Old 04-25-2016, 10:42 PM
  #96
ROG100
ROG100's Avatar
Just has to tell you when the level drops below a certain point and as long as that point is approx. at the half way point on the expansion tank it will be WAY accurate enough.
If it is accurate enough for the same function in BMW's I think it will be accurate enough for a 928.
ROG100 is offline
Old 04-26-2016, 12:11 PM
  #97
Jerry Feather
I found a source for the compound to make the seals out of. They recommend Nitrile. Then they gave me a quote to make the seals for me, but with the cost of "engineering" it makes them too expensive for the modest quantity needed for this project.
Then, last night, it occurred to me that I can do this with only one seal, the larger one for the top of the coolant bottle. What that requires is to simply glue the sealing ring I have made to the under side of the flange around the top of the new sender; then there is no need to seal the surface between the top of the sender and the cap.
I'm going to order a sheet of nitrile and then make the cutting die in my lathe and make some seals. That is, as soon as I complete the testing of these senders in the 928.
Old 04-26-2016, 05:37 PM
  #98
Jerry Feather
Well, I haven't done the 928 test yet, but I went ahead and made my seal-cutting die in my lathe. Here are some pictures of it with the other stuff so far.
Old 05-01-2016, 06:39 PM
  #99
Jerry Feather
I'm still waiting on the material for the seals. Then, now that it is a new month I can order the delrin for the caps and have that show up on next month's credit card bill. I hope I have the seal cutter sharp enough; but if not I can turn it again in the lathe. It is long enough so that I ought to be able to make several new blades on it if needed before I finish.
Old 05-12-2016, 08:10 PM
  #100
Jerry Feather
The Nitrile finally showed up after over two weeks since I ordered it, but it looks like pretty good material. I tried my seal cutting die on it and made a few seals, but I think my die is too sharp for as low grade of steel as I had to make it out of, so after just a few of these it is dull. I'm going to sharpen it and try some more, but I think I will be able to get plenty out of this material to meet our needs for a long time.
Here is a picture of the few that I have made so far.
I haven't ordered the delrin for the new caps yet but will probably in the next week.
Old 05-12-2016, 08:20 PM
  #101
MjRocket
Super User
MjRocket's Avatar
Nice!
MjRocket is offline
Old 05-12-2016, 10:17 PM
  #102
M. Requin
M. Requin's Avatar
Hi Jerry, can you try case-hardening the cutting end of the punch?
M. Requin is offline
Old 05-12-2016, 10:33 PM
  #103
Jerry Feather
Possible, but I haven't done that since my basic welding and forging class, back in the day.
I think I can sharpen it differently than I did the first time so that the cutting edge lasts better. I had the outer edge turned pretty thin and very sharp, but the inner cutter was more (less?) tapered and kind of blunt. The inner cutting edge actually is surviving very well and cuts pretty nicely the way it is. However, in order to sharpen the outer one I need to do both so that they cut on the same plane.
Even if I have to sharpen them a few times it will be less trouble than trying to figure out how to case harden them.
Old 05-13-2016, 10:04 AM
  #104
Imo000
Captain Obvious
Super User
Imo000's Avatar
Heat the end up red hot and dump it in a bucket of used engine oil.
Imo000 is offline
Old 05-31-2016, 05:13 AM
  #105
scottpeterd
User
scottpeterd's Avatar
Any updates on this? I'd love to try one as I've got my coolant tank out for service.
Cheers
scottpeterd is offline
Quick Reply: Possible cheap coolant level sensor replacement?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
