Possible cheap coolant level sensor replacement?
#31
I recieved mine, No cap as well...Which pisses me off because i needed the cap, which I was lead to believe was included. Anybody have a spare cap they would part with?
#35
Hi guys - looks like I need a coolant level sensor for my '91 S4 - has anyone confirmed this non-Porsche version works yet? Also if you receive it without the cap - does this make it unusable?
#36
I guess if I get to needing one of these, its something to re-wire and ignore.
If we overheat..we still have a pressure sensor, and a temp gauge, and when it leaks..we still have a nose, and when we check oil every few tanks of gas...we still have eyes.
#38
Basic Sponsor
Well electrically it works but the cap does not fit from the original sensor. It looks like it can be made to fit with a bit of whittling. As long as you have the original seal/gasket you should be good.
Mark - I have one here for you to try.
Nigel - I can get more if needed.
#40
Basic Sponsor
Sean and I looked at this further today. It will take a lot of "whittling" to make this work and seal on the top of the expansion tank.
The sensor will report a different level of lack of fluid - not a show stopper.
The new sensor will not pass through the hole in the original cap - probably can be overcome.
However the sealing face cap to sensor is none existent/way too small. As you screw the cap down the sensor will fall into the tank.
Here are some pictures.
