What size performance tires for 18" Panamera rims?
#31
I think it's about time to treat Kibort like GhettoRacer. Give him his own forum and let him run rampant though it so he stops ****ing up every thread.
#32
i think, with such an undersized tire up front (i.e. 225 or 235) its really hard for the car to really feel very stiff up front. it will always handle better as you spread the load over a wider tire, and thats why with a car like the 928, a larger tire feels much better handlingwise up front. after all most of the weight is up front. with near 900lbs siting on each front tire, and maybe only 700 in the rear, the fronts deserve more meat. and they tend to soften things up, and stabilize the ride as well. (going to a 245 or larger front tire)
Blather on.
#33
#36
no need to be rude Glen... but yes, stiff can make pot holes seem more jolting. BUT, a larger tire seems to mitigate the effects as well.
really? you have that much of a problem with information. ive tested almost all these combinations discussed... tire temps, wear patterns, etc. but you would rather hear from the bench racers? you are a piece of work... were you beaten as a child? just relax and take it all in. all im doing is providing information that I think can help. no one EVER has complained of the help ive provided on their 928s, especially to advice with tire size and fit.
Glen... have you checked your speedo for accuracy lately? trust me, its off anyway. in fact, it will be dead nuts on with a 26" rear tire, so there is some room to play with .
overall, the best tire sizes for the 8.5 and 9.5" rim would be the 255 and 275 combo. I have 10s of 10000s of miles on this combo with NO complaints or issues, wear, handling or anything else performance related.
however, on the small side, you could run the 245x40 if you have size limitations up front you are concerned with .
#37
Wheel offset it important to avoid rubbing. On my '87 S4, I went with the Panamera 18 inch 5 spoke wheels as per OP question. 8 in front ET 59, 9 in rear ET 53. 6 mm spacer in the back. No rubbing lock to lock front or rear, not that the back was a concern.
Tires - Michelin Pilot Super Sport. 245 35 Front. 265 35 Rear.
#39
To the OP Dennisrh: I had to do a double take when you posted the picture - I have the same Panamera wheels, and Michelin tires in that same size, plus my car is GP white with tinted glass.
I'm very pleased with my decision and hope you are too.
#40
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Hugo
#42
#43
curious as to what your backspacing is on your 12s? as you know, i have K18s as well. mine are 11" with 8" backspacing.perfect for the rear of the 928 and up to 305... no spacers. but, if you do some nice bat work, a 17mm spacer can be used as well.
be interested to hear of the backspacing of your 9" front rim, as it can accomodate a 275 with no issues. 255 for sure.
#44
i think i ended up machining down the spacers to 17mm so i could fit the 305 tire in the rear without any major fender work. (just some rolling)
#45
I just got a set of Panamera 5-spokes and have been shopping tires. The sizes I'm looking at are Kumho Ecsta 4X II 235-40-18 for the front and 255-35-18 for the rear. It seems everyone else is going 265 on the rear. Is there any particular reason I shouldn't go with 255?
Hugo
Hugo
255 was seemingly a popular section width with good availability for 17 inch wheels and 265 seems more common on 18 inch wheels for whatever reason. There is no reason I know of why you should not run with 255 on the rear end and in fact it is closer to the stock diameter of 25 inches than the 265 that is typically 25.4 inches.
Rgds
Fred
