928 Forum 1978-1995
Sponsored by: 928 Specialists
5 speed shifter boot base loose
Old 03-02-2016, 04:19 PM
prescott
prescott's Avatar
Default 5 speed shifter boot base loose
My 88 S4 5 speed shifter base and the attached leather boot has been loose and rattling around since I bought the car. My cigarette lighter tray is only screwed down by one tab to the center console and is somewhat loose (also broken by PO), which may be making it easier for the shifter base to "pop out". I've tried pinning the plastic rectangle below the center console tray and cigarette lighter tray when I had the radio out, but the shifter base came loose after a few days of driving. I don't find any retaining tabs under the plastic base to help hold it in position.
What is the best way to fix this problem? I've looked for write ups but come up short. The leather is in good shape, if somewhat dry. Leatherique conditioner and German Nivea helped somewhat.
If the shifter boot needs replacing, do you have any recommendations? Change out the shifter and boot at the same time? My interior is all black. That LED shift **** looked cool, if the LED bulb color could be light orange to match the rest of my lighting.
Thanks for your help!
Brian
Old 03-02-2016, 04:26 PM
James Bailey
James Bailey's Avatar
Your shift boot has shrunk which then keeps popping the shift frame out of the console....fix is new boot new shift frame, and possibly shorten the shift lever a bit
Old 03-02-2016, 04:37 PM
davek9
davek9's Avatar
Also you may want to check the play fore and aft (front cup is worn out) and where the lever is adjusted to when sitting in Neutral, also done at the front linkage on top of the TT.
Dave
Old 03-02-2016, 05:04 PM
prescott
prescott's Avatar
Thanks!
I have emails into Paul Champagne and Rob Budd to get pricing.
Anybody used one of these off fleabay?
http://www.ebay.com/itm/ICT-Porsche-...FWxvSn&vxp=mtr
Old 03-02-2016, 05:15 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Originally Posted by prescott
Thanks!
Carl @ 928 Motorsports is offering that, too.
Old 03-03-2016, 10:21 AM
Carl Fausett
Developer
Carl Fausett's Avatar
in stock.
http://www.928motorsports.com/parts/...shift_knob.php
Old 03-03-2016, 12:01 PM
DeMille
DeMille's Avatar
If you want to try the 'cheap and dirty' approach, ... I had the same problem.
Pull the boot straight off the shifter and cut the shifter down. (hack saw) It's been a while, but I think I took only about 1/2 inch.
Net result is a short shifter and a boot that stays in place. Zero cost.
Quick Reply: 5 speed shifter boot base loose
