New parts coming in
The Parts Whisperer
New parts coming in
This is a list of very old parts coming from a Porsche dealer. The price shown is list so there will be saving of that such as the GTS calipers. I know that Rob has already identified a NLA part that he wants for Minerva.
928-025-289-02 RUBBER SEAL 5.17
928-101-115-15 MAIN SHELL 76.18
928-101-115-50 MAIN BEARING SHELL 76.15
928-102-151-01 SOCKET SCREW 5.12
928-103-143-02 9.8
928-103-143-15 ROD BEARING 51.24
928-103-143-57 47.4
928-103-172-02 ROD NUT 2.58
928-104-115-02 GROMMET 2.56
928-105-157-50 TIMING BELT 54.48
928-105-215-00 CYL.HEAD PLUG 10.94
928-105-262-00 PIN 1.48
928-105-409-02 VALVE 153.06
928-105-410-04 EX VALVE 149.14
928-105-427-02 GASKET 36.12
928-105-509-01 TENSIONER 15.88
928-105-539-03 PLATE 5.45
928-105-552-06 BOOT 23.51
928-105-571-00 TENSION ROLLER 92.35
928-106-113-02 FAN PULLEY 83.88
928-106-163-00 THERM GASKET 13.95
928-106-197-04 GASKET 3.01
928-106-323-01 RUBBER HOSE 19.95
928-107-165-00 WASHER 2.97
928-107-166-00 WASHER 5.99
928-107-169-01 GASKET 4.58
928-107-180-01 SCREW 7.43
928-107-181-01 SCREW 12.89
928-107-201-05 OIL FILTER 19.81
928-107-201-07 OIL FILTER 13.08
928-107-603-00 HOSE 88.96
928-107-722-00 HOSE 37.68 SOLD
928-110-014-01 PLASTIC PIPE 21.1
928-110-147-05 FUEL FILTER 27.12
928-110-150-01 LINE CLIP 2.31
928-110-224-00 AIR HOSE 44.52
928-110-253-05 FUEL FILTER 35.69
928-110-253-06 FUEL FILTER 32.12
928-110-377-04 FUEL LINE 63.1
928-110-378-03 FUEL LINE 54.32
928-110-429-08 VACUUM VALVE 41.14
928-110-441-02 AIR DISTRIB FITT 29.09
928-110-442-05 HOSE 11.85
928-110-475-03 NUT 6.54
928-110-650-00 1.54
928-110-673-00 HOSE 79.95
928-110-698-01 SLEEVE 5.05
928-110-713-01 GASKET 16.11
928-110-714-01 GASKET 16.11
928-110-761-01 HOSE 14.72
928-110-904-00 15.14
928-111-127-02 GASKET 21.33
928-111-149-03 CO TEST PIPE 48.07
928-111-181-00 WASHER 1.63
928-111-193-12 GASKET 10.82
928-111-246-05 SEAL 47.27
928-111-261-02 BRACKET 10.4
928-111-271-01-ORI BLACK TIP 20
928-111-288-00 SUPPORT 55
928-116-085-08 REALEASE BEARING 372.43
928-201-107-02 130.78
928-302-167-03 OIL SEAL 30.78
928-302-318-01 TRANS.BRAKE BAND 61.61
928-302-322-00 ANCHOR BLOCK 30.1
928-315-211-02 VALVE 200.55
928-331-075-04 BOLT 32.18
928-331-581-00 WASHER 12.28
928-331-588-10 BUSHING 53.26
928-332-030-08 SPLINED JOINT 421.28
928-332-097-03 JOINT FLANGE 194.52
928-332-257-00 CLAMP 3
928-332-257-01 CLAMP 7.44
928-332-267-01 SPLINED 19.5
928-332-293-02 DUSTBOOT 55.71
928-332-551-00 DIFF DISC 2.0MM 68.66
928-332-555-00 CUP SPRING 28.92
928-332-775-12 TRANS SLAVE 840.23
928-341-065-02 HUB 492.66
928-347-739-02 SLEEVE 12.77
928-347-927-00 O RING 3.95
928-347-962-00 STEERING INT. PIECE 3.91
928-351-043-60 DISC 189.53
928-351-044-60 BRAKE DISC 189.53
928-351-423-03 CALIPER 1091.09
928-351-424-03 CALIPER 1091.09
928-351-917-00 REPAIR KIT 27.97
928-351-919-10 REP KIT 55.72
928-351-935-00 EXP SPRING 23.81
928-351-936-00 RETAINER 5.19
928-351-943-00 CALIPER KIT 11.2
928-351-950-01 SPRING 93.13
928-351-971-00 BRAKE LINE 117.6
928-352-096-11 BRAKE VIB 10.03
928-352-097-10-SAM BRAKE SHOES 42.16
928-352-421-03 CALIPER 1236.08
928-352-953-00-SAM BRAKE HDW 36
928-352-963-00 WASHER 3.61
928-355-637-01 LINE HOLDER 4.15
928-361-032-02 HUBCAP 65.59
928-361-047-50 KEY BLANK 3.74
928-375-166-01 RUBBER BUFFER 2.55
928-423-349-01 GUIDE 15.87
928-423-351-00 CLUTCH SPRING MOUNT 87.81
928-423-353-00 WASHER 16.81
928-424-181-03 SHIFT SLEEVE 23.15 SOLD
928-424-181-04 SHIFT SLEEV 10.21
928-501-033-03-GRV CROSS MEMBER 603.91
928-503-255-00-GRV WASHER 5.22
928-504-316-03 COVER 47.75
928-505-043-00 BUMPER RETAINING 13.78
928-505-056-02 FRAME 48.2
928-505-113-20 FRT.BUMP COVER 1574.24
928-511-173-02-70B COVER 19.88
928-512-165-02 HATCH LOCK PIN 1.74
928-512-169-03-01C RUBBER GR 8.09
928-512-331-05 STRUT 17.34
928-521-101-08 THREADED PLATE 19.35
928-521-147-02-01C HINGE CVR 61.46
928-521-147-02-7XJ SEAT HINGE COVER 19.3
928-521-147-02-9MM COVER 60.01
928-521-148-02-01C SEAT HINGE COVER 75.35
928-521-760-05-01C SEAT TRIM 16.71
928-528-071-02-03C NOZZLE 16.71
928-528-181-02 WASHER TANK CAP 17.15
928-531-235-03 MIRROR MOUNTING 12.05
928-537-063-04 L DOOR HANLE 61.45
928-537-111-02 LOCK OPERATING ROD 5.16
928-537-153-03 DOOR LOCK 53.89
928-537-260-02 WINDO GID 20.83
928-537-290-02 WINDOW GUIDE 25.84
928-537-342-02 WINDOW VIB BUFFER 5.18
928-537-419-03 DOOR BOLT 8.59
928-537-426-02 DOOR HAND 3.53
928-537-639-01-AM KEY BLANK 9.18
928-537-917-00 STEEL RIVIT 5.16
928-543-415-05-70K CORNER 17.58
928-543-417-09-70K MOLDING 17.21
928-543-418-09-70K MOULDING 16.12
928-543-419-09-70K MOULDING 13.79
928-543-420-09-70K MOULDING 18.08
928-551-056-02 BODY SCUFF PLATE 98.24
928-552-055-03 COVER 56.25
928-552-317-02 SPACER 3.07
928-555-355-02 **** 3.17
928-555-359-02-70B PUSH BUTTON 3.45
928-555-565-02 BUSHING 1.85
928-555-569-02 GUIDE SLEEVE 4.97
928-555-607-02-70B PLASTIC **** 4.76
928-555-741-02 CASSETTE 16.56
928-559-107-02 TRIM CLIP 1.45
928-559-143-02 RUBBER 0.22
928-559-214-05-70K MOLDING 10.27
928-559-285-02 WIND 2.2
928-564-125-02 PINIONGEAR 32.97
928-570-423-00 SPRING 2.45
928-573-096-03 VALVE 14.84
928-573-727-05 RUBBER 17.35
928-574-040-03 LOUVER 82.62
928-574-087-03 AIR VENT 40.06
928-574-093-03-70B SWITCH **** 10.41
928-574-498-03 CLIP 4.42
928-574-573-03 HEATER VALVE 112.49
928-574-717-02 CONNECTOR 4.48
928-574-717-05 RUBBER HOSE ELBOW 8
928-602-039-00 WIRE 64.05
928-602-103-00 PLSTC SEAL 8.2
928-602-211-01 CAP 145.51
928-603-904-00 NUT GEN 21.86
928-606-201-03 SENSOR 103.42
928-606-221-00 AIR FLOW PLUG 16.29
928-608-013-00 FUEL PUMP 489.9
928-609-061-05 WIRE 86.27
928-610-511-00 CARRIER 9.73
928-612-009-13 CABLE 82.02 SOLD
928-612-361-00 CABLE TIE 4.26
928-612-566-00 ELEC PLUG 2.36
928-613-049-00 MICROSWITCH 135.35
928-613-125-00 SWITCH 65.37
928-613-129-03 WIPER SWITCH WITH HARNESS 70.12
928-613-131-01 TEMP SENSOR 129.6
928-613-147-00 SWITCH 32.39
928-613-181-00 SEAT SWITCH 139.39
928-613-183-00 SWITCH 203.63
928-613-308-01-01C COLUMN SWITCH ASSY. 291.4
928-618-930-00 RELAY 104.67
928-624-312-01 HOSE 7.43
928-628-074-01 WASHER PUMP 128.85
928-628-077-00-70B WASHER NOZZLE 50.67
928-628-091-00 WASHER TANK 48.75
928-628-218-01 WIPER BLADE 16.52
928-628-621-00 WIPER ARM CAP 3.29
928-628-623-00 WIPER CAP 9.01
928-628-623-01 CAP 4.26
928-628-901-02 WIPER BLADE 31.41
928-628-901-03 WIPER BLADE 37.81
928-631-443-00 POSITION 309.9
928-631-924-00 CELL RUBBER SEAL 7.83
928-631-932-03 TAIL LIGHT 405.17
928-632-109-01 LIGHT 62.74
928-641-983-00 BULB 6.97
928-645-423-00 SPEAKER GRILLE 33.49
928-701-050-03 BRACKET 35.73
928-701-133-02 RUBBER BUFFER 3.47
928-731-043-02-70B MOUNT 11.22
928-750-327-03 RIM 65.36
928-803-126-09 SEAT BELT 274.89
928-803-141-00 SB COVER 6.88
928-803-151-02 SEAT BELT 2.45
928-803-153-02 CLAMP 2.45
928-803-212-02 WASHER 15.9
928-103-143-02 9.8
928-103-143-57 47.4
928-110-650-00 1.54
Mark - PM sent.
