10 years in hibernation - coolant deposits
Heads and block are finally back from the machine shop. Some Corrosion on the heads but looks to be only in the water jacket area. I may need to fill a few spots with JB Weld.
The shop did the following:
-Machine heads
-Replaced valve seals
-Removed the steal oil galley caps (so I can clean again)
-Mnaully cleaned the heads, no blasting
-Machined block deck and replaced alignment pins etc.
-And R&R the cylinder walls
