New member
Next time it is running, check your ignition monitor relay - right side of the passenger footwell, behind the carpeting, by the LH controller/ECU. It has a clear plastic case. Are either the green or red LED's lit up? I wouldn't run it long especially if you are smelling gas.
See my post above. Your symptoms sound like the injectors are running on a fixed pulse width which is the limp home mode that the ecu defaults to when the maf signal is out of range. Even if there are other problems, having a known good maf will simplify diagnosing the car.
That's a much better intro post than the rash of "tell me how to my umpteenth vanity car that I'll never actually work on"!
Welcome! folks here enjoy resurrections and helping a car come back to life!
Thanks Hilton. I read your post which makes a lot of sense. I just purchased a MAF from Tom at 928International. Meanwhile I'm waiting I'll be cleaning all grounds. A lot of work with too little time but it's going to good!
Guys my 928 is an Automatic and the transmission is stuck on parking. The shifter moves ok up & down, but it doesn't disengage from parking. I opened up the shifter plate and the cables look attached from there...haven't been able to go look at the rear portion of the cable attachment. Any ideas?
Sounds like broken/disconnected cable at the trans in back.
When I bought mine the auto shift cable was binding so I replaced it. Here is my thread on the issue. It might be of some help to you.
https://rennlist.com/forums/928-foru...k-in-gear.html
For us newbies, how do we do this? Are there any instructions with photos or video links available?
It is for a MY 88, but the essentials should work for you.
Also see the remainder of Dwayne's write ups for other jobs - they are used by many here.
Well...need to continue searching for the problem. I installed the new MAF and it did the same thing when I started her up. Barely idle for a 15-20 seconds and it stalled. I had to charge the battery. Installed it again and since then nothing. Cannot get it to fire up. I can smell fuel. Left it alone because it's probably flooded. Came back at this this morning but nothing. It cranks but doesn't fire.
How is it running, is it idling correctly, is it sputtering, does it sound like all 8 cylinders are firing? Check the firing order on the ignition wires and both distributors. Also make sure that both distributors are connected properly and grounded.
Good luck and welcome to the club,
Michael
