climate control upgrade
#48
I have measured as much as 0.5a on the solenoids. A standard octal high-side driver would run them no problem. ST, Infineon, and ON all have nice single chip solutions with built-in fly-back protection for the inductive load. There are a couple digital pots out there that should work now, like the AD5290 or MCP41HVX1. That was kind of the stumbling point before. If you want to mimic the original design, you needed a digital replacement for a 1/8W pot, but you could theoretically use a DAC instead. I never tested this personally, but think it should work in the servo loop for temperature control if you are sampling external sensors instead of using the factory thermistor style sensors.
#49
Thanks Hans - didn't know about those driver chips. I'm looking more for DIP packaging, and will likely run separate relays for the main outputs, with plenty of overhead on the current to allow for other uses if someone wants to try. The ***** I'm working with are 10KOhm 0.1W pots. The last challenge is the hot/cold pot output - converting it to replace the stock head's 200-1200Ohm resistance, trying to keep the mixing motor and thermistor sensor string intact.
#51
Can anybody do some Ohm checking on the stock 928 HVAC control? Need to verify the resistance of the potentiometer controlled by the Cold/Hot slider, with no other temp sensors in the loop. Hoping to hear from several different model years (early to late). I'll start - my 1980 Euro S measures 750-1781Ohms. I am asking for more input because of the difference of 200-1200Ohm previously mentioned, vs what I measured on mine last night.
#52
#54
All you need is to print or cut cams that fit on the back of the shaft to engage a min and max limit switch if you want to use a standard pot.
According to my old notes, the stock pot is 2.2k 1/8th ohm. It is used in a range of 200-2200 so a total of 2k range over 20 steps. Each increment in temperature is represented by a set of 100ohm.
I have some circuit boards here from when I was playing around with this to convert the factory card interface to ribbon cable. I can dig those out and send one to you if it helps.
I have a lot of documentation, schematics, and files from various efforts on this if it helps. Feel free to pm or email me.
#55
Al, I have a spare controller, that has unknown history...it is in fair condition...think it's from an 82. I will send it to you, if you need or can use it for testing. Also, I believe the solenoids are still intact, on the 84 parts car.....let me know what you need, I would be happy to be involved.
#58
Here is the wiring/service manual in PDF for the Sentra manual AC controller. It uses a LAN, but it seems to be internal to only the door motors and HVAC unit itself for feedback of door position. Also describes some but not all pin assignments for the connector on the rear. System description starts around page 20. Hope it helps the research
Cheers!
Carl
Cheers!
Carl
Pins
1 IGN (on/start)
2 BAT
3 GND
4 COMP ON (runs to BCM)
5 VACTR (runs to air door motors)
11 LT-ILL -
12 LT-ILL +
15 LAN SIG (feed back from air door motors)
17 FAN GATE (runs to Fan Control Amp)
18 FAN F/B (from F.C.A.)
19 FAN ON (runs to BCM)
20 IGN 2 (on only)
22 RR DEF SW (goes to BCM)
23 RR DEF SW (in from relay)
24 SENS GRD (goes to intake sensor ?)
25 INTAKE SENS (goes to intake sensor ?)
30 AC PD CUT (goes to ground)
Rear defogger, A/C clutch on/off and fan speed control seem straight forward to integrate. Going to get a new blower motor while it's ripped apart. Recirculate, Temp and Vents involve LAN and need more thought. Definitely not a plug and play conversion. Maybe head to a U-Pull It salvage yard and pick up the door motors to experiment.
#59
State Electronics, Part # L25392. This potentiometer is equipped with two limit switches that operate individually at each end of the pot's rotation, eliminating the need for cam operated microswitches. I requested a quote and got a price of 38.93 each, minimum 5 plus a 50.00 setup charge. That was in 2010.
