928 Forum 1978-1995
Sponsored by: 928 Specialists
Stranded in Van Horn, Texas
Old 06-12-2015, 05:10 PM
  #31
Drewster67
Drewster67's Avatar
Dan is the ONLY person to work on my track beast -
You are in great hands.
Old 06-12-2015, 05:38 PM
  #32
dr bob
Chronic Tool Dropper
dr bob's Avatar
Don--
You are in excellent hands with Dan W working on the car. It will be interesting to see what the suction strainer looks like when he gets it removed. It's a bit of nylon sock that is supposed to keep the rocks out of the pump. If it's clogged or is disintegrating, it certainly would contribute to the pump symptoms. Particularly if the symptoms started right after a fill-up, I wouldn't plan on gas from that station on the way home.
Travel safe, enjoy the ride!
Old 06-12-2015, 07:35 PM
  #33
Don Carter
Don Carter's Avatar
Dan got us taken care of in less than 2 hours. He even delivered us to a nearby upscale shopping center where we ate lunch and he picked us up when the car was ready. He said that the fuel in the filter was VERY hot, much hotter than he normally sees and hotter than the tank gas. His theory is that the issues with the FP were causing it to super heat the gas, causing the issues Bob described. I've got the old pump and he said I should test how many amps it's pulling when I get home. He suspects it's pulling a lot of amps and heating up.
The strainer doesn't look bad at all for 30 years of use. It doesn't look clogged and has no visible holes in it.
I was really impressed with Dan and his shop. Probably the nicest mechanic I've run into in years. Phoenix is lucky to have him in town. He's also got some interesting projects. Check out this custom spider intake on his track car.
We should now be good for the slow drive home over the next few days. Thanks to all contributed to troubleshooting the issue. I've learned a lot for sure (think twice about taking a 30 year old car cross country :-) )
Old 06-12-2015, 08:13 PM
  #34
Chuck Schreiber
Chuck Schreiber's Avatar
Don,
Not sure how I missed this one....???
Glad it all worked out!!
Old 06-13-2015, 12:06 AM
  #35
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by Don Carter
... I've learned a lot for sure (think twice about taking a 30 year old car cross country :-) )
Nah - where's the fun in NOT going? Now you have stories to tell...
Alan
Old 06-13-2015, 01:29 AM
  #36
James Bailey
James Bailey's Avatar
there have been a few cases where the screen came loose from the bung and floats around in the tank until the solid end gets sucked up to the outlet cutting off the fuel...shut down tow the car and the screen moves away from the outlet and car starts and runs fine.....until the screen end get sucked up to the outlet again......yes it happens
Old 06-14-2015, 05:46 PM
  #37
Don Carter
Don Carter's Avatar
No issues yesterday or today ( so far). On I40 headed to NM.
Old 06-14-2015, 09:56 PM
  #38
redpathtribe
redpathtribe's Avatar
Great news Don, hoping you can relax and enjoy the rest of your trip and not worry about any more "issues"!
Old 06-14-2015, 10:13 PM
  #39
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,624 Likes on 1,476 Posts
funny thing with the 928,
the more you drive it the better it runs.
Don , I am glad you got a new pump installed,
I hope the rest of your trip will be non eventful.
Old 06-15-2015, 04:11 AM
  #40
UpFixenDerPorsche
UpFixenDerPorsche's Avatar
Keynote speaker (and state president of) at a commercial van owner's association conference years ago was a Dutchman by the name of Van Fleet. No kidding. :-)
Sorry - couldn't resist.
Old 06-16-2015, 03:20 PM
  #41
Don Carter
Don Carter's Avatar
The car is still running good, but now we have a tropical storm crossing our path home to Houston today. Could be interesting...
Old 06-16-2015, 03:23 PM
  #42
James Bailey
be sure to check / clean out the drain flap on the firewall !!! otherwise water can flood in the blower fan and run down on the fuse panel..
Old 06-16-2015, 04:08 PM
  #43
Don Carter
Don Carter's Avatar
James, thanks I'll check it out.
Old 06-16-2015, 05:02 PM
  #44
Kiln_Red
Kiln_Red's Avatar
Big +1 to that point. True of any and all 928s I've had anything to do with.
Old 06-16-2015, 10:08 PM
  #45
Alan
Electron Wrangler
Alan's Avatar
So how was the giant hole in the ground? Glad its all working out on the way back - think of it as stress testing - now you know its good for another long trip...
Alan
Quick Reply: Stranded in Van Horn, Texas
