928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing Porsche wheel locks
Old 06-01-2015, 02:39 PM
Hobibill
Hobibill's Avatar
Default Removing Porsche wheel locks
Just bought this 80 5SPD and the key I have doesn't work the locks. What's the best way to remove them?
Old 06-01-2015, 04:52 PM
GlenL
GlenL's Avatar
Chisel and a hammer.
Old 06-01-2015, 05:30 PM
Randy V
Randy V's Avatar
Go to the local Dealer - they should have one you can borrow.
Then throw them away and replace with standard lugs.
The only one ever deterred by wheel locks is the owner of the vehicle.
Old 06-01-2015, 05:40 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Slide Hammer - screw it into the lock and pull.
Old 06-01-2015, 06:03 PM
jheis
jheis's Avatar
^^^ This.
I've posted this before, but one of the receipts that came with my '82 said something to the effect of: "Tow car to shop. Drill out 8 (!) wheel locks..."
As JB said, there is such a thing as being too careful.
James
76FJ55
76FJ55's Avatar
Those are very simple disc tumbler locks. you don't even have to rotate the lock core to extract them. if you have something thin that you can fit into the key slot, just apply slight pulling pressure on the housing and stick the thin object into the key slot and rake across the tumblers. The pressure should hold them until the lock slides to the next detent. There are I believe 4 discs, so repeat until it comes off.
Old 06-01-2015, 06:16 PM
Hobibill
Hobibill's Avatar
Thanks! I'll try this with the key I do have. If that no worky I'll get out the slide hammer ; )
Old 06-01-2015, 07:47 PM
Jfrahm
Jfrahm's Avatar
Yes they can be "rake picked" very easily. If the whole lug cover rotates too much it can be wedged with a piece of cardboard. Once the locking cover is off the lug underneath can eventually be replaced with a standard one, or tolerated.
Old 06-01-2015, 08:14 PM
RedTele
RedTele's Avatar
Grab a drill and a bit. It'll take you about 30 seconds.
Old 06-01-2015, 08:26 PM
Hobibill
Hobibill's Avatar
The wheels are free!
Quick Reply: Removing Porsche wheel locks
