928 Forum 1978-1995
Sponsored by: 928 Specialists
Manifold Flappy Question
Old 11-30-2014, 06:18 AM
DeWolf
DeWolf's Avatar
Default Manifold Flappy Question
Hi All,
How much difference does a working flappy make to the performance? I've got the manifold off the S4 and if I suck on the hose to the flappy actuator it just pulls air and the rod does not move. If it doesn't make a diffrence i'm not going to pull the manifold apart to replace it.
Cheers
Scott
Old 11-30-2014, 09:46 AM
ammonman
ammonman's Avatar
The resonance flap extends the peak torque range from 2800-3600 rpm to 2800-4800 rpm and steepens the horsepower curve in the 3600-4800 rpm range. It doesn't open until about 3600 rpm as the torque is starting to drop off and closes again at around 5400 rpm when there isn't any more gain to be had. When it works properly you will notice that as the motor starts to flatten out around 3500 rpm it suddenly starts pulling hard again. It is well worth installing a new actuator while you have the manifold off.
Mike
Old 11-30-2014, 01:24 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Before you replace it, make sure that you were sucking on the right hole...
One hose fitting is the vent, and won't hold vacuum. The other is the actuation, and will hold vacuum.
Old 11-30-2014, 01:41 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Timely thread, I was just in the garage playing with the flappy on the 87, using the Mighty-Vac on the two lines going to the flappy solenoid.
Neither holds vacuum so I've got that going for me....... I was bored so having to pull the intake is a pleasant addition to my to-do list.
On a side note, these plastic vacuum lines are horrible.
Old 11-30-2014, 02:09 PM
UpFixenDerPorsche
UpFixenDerPorsche's Avatar
Originally Posted by DeWolf
Hi All,
Cheers
Scott
Makes about 30hp difference at the top end, but the performance is sharper from 4k up.
I too had this problem and I liken removing the manifold to poking hot needles under my fingernails (not that I've actually done that but I did get a little splinter once).
Decided to do something about it as I wanted the lost horses back: (Apologies to Dwayne )
WARNING: THIS CANNOT BE UNSEEN :WARNING
Manifold is now off as I had to fix an oil leak er flood from a tired gasket at the base of the filler neck.
Old 11-30-2014, 03:37 PM
J1720
J1720's Avatar
Very creative!!
Old 11-30-2014, 06:34 PM
Hilton
Hilton's Avatar
I used to think that - however I'm putting the plastic lines back onto my 89 after 6 years of silicone vacuum lines, as the prospect of fuel in silicone lines worries me. The factory system of plastic and rubber elbows is at least more fuel proof and gives a longer opportunity to notice/diagnose a running problem before the car goes "woof".
John - thats an impressively engineered solution!
The flappy makes no difference to peak horsepower. It closes again at around 4500rpm so when its not working its the same at low rpms and high rpms a it it were working.
What it does do is change the intake performance to add a second torque peak in the mid-range, filling in a large hole in the torque curve - it makes a very noticeable difference in pulling power. There's a factory chart of the difference between op/inop which gets posted from time to time.
Old 11-30-2014, 06:56 PM
mark kibort
mark kibort's Avatar
I did the dyno test with no flappy vs flappy.
yes, as we all know, low end torque is happy with flappy, but past 4000rpm there is no difference
so, when racing , I never drop below 4000, so there is no difference with or without flappy.
It doest hurt top end HP BUT, if it doesn't open up, it will kill HP in the 5k range, so better to wire it open or remove it as I did, then to worry about it not opening up.
Old 11-30-2014, 08:07 PM
Hilton
Hilton's Avatar
Here's the factory chart:
Old 11-30-2014, 08:13 PM
J1720
J1720's Avatar
Great chart!
Old 12-01-2014, 07:32 PM
UpFixenDerPorsche
My mistake Hilton. You're dead right.
I was thinking of the power difference at the rpm of the second torque peak (or not).
Have marked it on same chart below. It's about 20kW (25hp).
Cheers.
Old 12-01-2014, 08:33 PM
mark kibort
so, again, if you lock it open, if you never go below 3600rpm in anger, it's not a factor, and you don't need flappy. But, if it isn't working.... its costly!
Old 12-01-2014, 10:34 PM
SMTCapeCod
SMTCapeCod's Avatar
Default retrofit
So is the main issue with a retrofit onto S3 the linkages?
The fitment is same at the head, right? Or are the fuel rails also a problem. Guess that's rhetorical, typing fingers let my brain actually work...
Too bad, the intakes would be cheap, the flappy functionality would probably be a hoot with the S3 cams, and the increased space could afford more creative approaches to broken intake bits and victor-type forced induction.
Edit, as is often the case- sketchy idea already/previously asked and well-answered.
https://rennlist.com/forums/928-foru...-s3-block.html
Old 12-05-2014, 06:27 PM
hacker-pschorr
The cloth covered flexible hose I use is rated for fuel.
It looks great, lasts a very long time and holds better than the plastic lines & elbows.
I have 3 different sizes on hand.
https://vwparts.aircooled.net/3-5mm-...-p/n203531.htm
Roger can get it by the foot.
Old 02-08-2018, 03:09 PM
PcarMiami
PcarMiami's Avatar
Been getting used to driving my 90 GT, I’m now starting to freshen up my 88 S4 for the summer—-all new runner.
The power is quite different, my S4 feels kinda dead till the flappy opens up at around 3500rpm. Starting in second doesn’t help either.. Even under part throttle while holding the gear, car just feels happier after 3500rpm. So I’m thinking... how would it feel with that flappy open all the time??? It can’t hurt?
I know I’m comparing it to the manual car, but I’m just looking for ways of making it funner without speeding like a nut.
Quick Reply: Manifold Flappy Question
