Manifold Flappy Question
Been getting used to driving my 90 GT, I’m now starting to freshen up my 88 S4 for the summer—-all new runner.
The power is quite different, my S4 feels kinda dead till the flappy opens up at around 3500rpm. Starting in second doesn’t help either.. Even under part throttle while holding the gear, car just feels happier after 3500rpm. So I’m thinking... how would it feel with that flappy open all the time??? It can’t hurt?
I know I’m comparing it to the manual car, but I’m just looking for ways of making it funner without speeding like a nut.
There shouldn’t be much difference in torque curves between S4 and GT below 3500rpm so the difference you’re feeling is likely the transmission type and gear ratios. But it’s worth it to check if the flappy turns. It would feel a little gutless under 3500rpm with flappy stuck open.
The GT’s engine is totally different feeling, it’s a willing rever at any rpm. Gearing feels shorter, so it probably helps a bit also. The S4 does seem to get its second wind at about 3500rpm, but during normal driving it rarely gets there. Just wondered if there was a way to get the flappy to open like at 2.5k? Would probably liven up the car a bit. I looked up the GTS dynamic kick down mod, it’s a lot of work for just a drop down in gear
I think the partial throttle torque is pretty much irrelevant. You can always press the pedal more or less to get what you want. What's more relevant is the stability of the partial throttle torque, in two ways. First, as the rpms change you want the same amount of torque at the same throttle angle to have a nice to drive car. This might be worth testing, but I expect there not to be much of a difference between flappy open and flappy closed modes. Second, at a given cruise rpm, you want the same throttle angle to result in a consistent amount of torque. With high overlap cams and a single-throttle plenum manifold, you can get the torque to be unstable and the engine surging and buckling. This is not relevant with S4 or GT cams, as they don't have any overlap to speak of.
Received 1,543 Likes
- Flappy not operating properly on S4. Vac lines switched? Etc.
- You S4 isn’t operating as close to factory specs as your GT.
- 2.20 rear end on your S4 vs. 2.73 on your GT. Night and day difference in butt-o-meter feel.
Is your S4 auto or manual? If the former, then add proper transaxle operation to the above list?
PcarMiami, what condition is the S4 Auto, are you sure all is working at 100%, MAF, Knock and HAL sensors, car will run fine/OK even if they are not 100% but will be down on power?
There is a big difference in GT to an S4 as already pointed out, and if you are not running out 1st gear that too will make the launch feel heavy..
As far as Kick down goes just add an additional switch inline w/ the peddle Kick down and bump it to first if in second and at low RPM.
The 88 is an auto. I tested the flappy with the tape over the bolt method, great way and saves lots of headaches. The flappy on the 88 auto switches at 3.5K when I rev at idle, the GT turns at 4K exactly.
Administrator - "Tyson"
If you're not knock limited, then absolutely it does the same for you as with a normally aspirated car with a turbo or centrifugal supercharger. If you are knock limited at say 2500 rpm and have to bleed of exhaust in a turbo or boost in a belt-driven supercharger at such a low rpm, then the flappy doesn't help much.
Rennlist Sponsor
If using the "correct" type of boost, there is NO Flappy to worry about..ha, ha! J/K
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
The only way I know of that it can be adjusted is if you have access to and use Sharktuner. The command to open is generated in the engine management computer and that thing either works or it does not.
