Thrust Bearing Failure (Almost?)
Team Owner
It would prolong the life of the thrust bearing if you first start the engine,
then press the clutch this will let oil fill the thrust bearing,
though there will still be oil in the crank groove prior to starting
Even my latest work truck now has one (14 International ProStar semi). None of the old ones did (mix of Freightliners and Internationals).
If the clutch isn't down to the floor, the starter won't crank.
Here's my 100k mile '87 auto with early TBF. Its been a long time, but I think max speck is .015". This measured at .019". No damage to engine. I put in new mains and rods and she was just fine. Although, its a lot of work..
On a manual car does the crank continue to grind against the thrust bearing after the car is started, or is it only during start up when the clutch is in that we need to worry? Does the wear stop once the oil is slung in to the space between the face of the bearing and the crank?
