S4 hot power loss, glowing cats.
#31
Chronic Tool Dropper
Got a spare LH brain to try?
#32
if cats are plugged wouldn't they run hotter and cause sluggish performance with a light load…..hmmm, pulling them sound pretty easy for the result may find one of the issues….I like bc's idea here….but I know dr bob is right with his diagnostic pathway...
#33
Archive Gatekeeper
Brendan, spanner's in the mail. I have a spare LH brain here for testing purposes if you need. Holla back.
#34
What I can do relatively quickly is out a test pipe in.
Really frustrating because it's never the same stuff over again and in my experience. It's always something slightly different.
#37
I have verified tps and temp 2 (temp II) at the ecu plugs. Higher ohms than 250, but it's about three hours since the car ran.
I'll probably wake in the morning and put the h pipe on.
Then I can also run a wide band to see what's up there.
Ken - is there more detailed instructions for the three pin pot plug and the knock thing?
I'm an IT director - I just send checks to the guys that do the actual wiring. But I sure can read a manual and set direction and policy on a project from that.
#38
Ohmed the coil wires.
I would need a well running 928 to check against, but when its cold and for 5 minutes of running after that, its okay. Not wonderful though.
#39
Swapped to an h pipe.
Swapped drivers coil.
This was after a test drive where it can barely idle now. Sounds like a pro stock with a lumpy idle.
Not a 4cyl idle. A bad v8 idle.
No change with coil, a different igniter.
Hot idle bad. Starts cold okay but got worse quicker with no cat.
#40
Next?
#41
How do I check the maf ohms at the ecu pins? Looking for that link.
#42
Administrator - "Tyson"
Did you plug in the wideband? What does it say?
Compression check?
Did you try a different LH / EZK?
Do you have a spare MAF?
Compression check?
#43
I'm. Going to swap to an unrequited maf. It's an unknown quantity but I'll take any evidence right now.
Car has 78k on it and it ran basically fine before I fvcked with it and started replacing parts to "make it better".
I do to have a other lh. And if I did, the car had porkens chips and 24lb injectors.
#44
Archive Gatekeeper
I wonder whether it's chip-related. Do you have the MAF screens and Ken's other recommendations? Colder plugs? 89+ octane?
Recommendations (from liftbars.com):
- Rebuilt MAF
- New knock sensors
- New CPS (crank position sensor)
- New TPS (throttle position switch)
- New hall sensor (cam position)
- Cam timing: 0° (-2|0 cold, PK32V'r)
- New OEM O2 sensor (not universal)
- Bosch WR5DC (7992) spark plugs
Required:
- S4 camshafts
- MAF screens installed
- 24# injectors (special o-ring)
I can still pop an LH and a known good MAF in the mail later today, am gone for a week starting tomorrow. I know it would be rich with the 24's but a good O2 sensor might get it close enough to at least run semi-normally (?)
- Rebuilt MAF
- New knock sensors
Required:
- S4 camshafts
#45
The glowing cats bit , reminds me of the 1989 > 928S4/GT/GTS that have old age trouble with their Exhaust Temp Monitoring system ( ETM ) ,that cuts out the ignition on one ignition bank ( kills one coil /module)
So if its a 1988 year type then there is no ETM , but it doesn't mean you do not have an issue with ignition on one coil bank , and yes they do still idle ( very low ) running on 4 cylinders( which makes the cats glow ,because of raw fuel still being injected) & yes they very much feel like they are being pulled back
Quick check for you to do with the engine idling }
Disconnect one of the two mutiplugs from the ignition modules ( next to the engine lid lower catch)for just a few seconds , reconnect then disconnect the other , again just for a few seconds ( this just stops their relevant coils) , if both ignition modules/coils are working then you will see little no difference in disconnection one as compared to disconnecting the other , meaning on a 928S4 that is idling at the correct RPM , all that happens is a drop in RPM , the idle control motor compensates immediately and raises the RPM , mild vibration from the imbalance , but the engine still idles , so in a case where both ignition banks are correct you get same result with disconnecting either module
Now if one module is not working , if you disconnect this one ( multi plug ) you will see do difference at all , because its not working , however if you then disconnect the other one then the engine cuts out , because its the only one working
And yes we see a few ignition modules play up every year( be it 944S2 , 928S4 , 964 etc etc ) as they reach old age & yes only replace with the correct Bosch type , because the non Bosch ones give us the most trouble
Ignition module 928 602 706 01 ) Bosch 0 227 100 124
