928 Forum 1978-1995
Sponsored by: 928 Specialists
The last of the PO's aftermarket wiring...wired to starter
Old 06-07-2014, 05:12 PM
Five-8
Five-8's Avatar
Default The last of the PO's aftermarket wiring...wired to starter
HI All
After having pulled a ton of aftermarket wiring off this car, i think i am down to the last of it.
First pic is top end of this wiring with the two (black and blue)wires originating from the starter.
As you can see--into a relay:red to a 30A fuse and then onto jump post:yellow grounded to cross support mount.
Pic 2 is the other end.
The blue and black then become the two heading into the heat shrink connections and one to the wiring harness and two to the starter.
I have a new wiring harness(starter to 14 pin) from Carl which i will install after i finish cleaning, what i would like to know...can i eliminate this non original wiring completely and attach the 3 wires in the new harness to the starter?
What was the purpose here for the additional wiring? Immobilizer? If so is there any chance removing this will immobilize the car?
Thanks as always!
Old 06-07-2014, 05:14 PM
Five-8
Five-8's Avatar
Thought i better add this pic.
I assume the white wire is to go in place of the wire that had been joined in the 2nd pic.
Old 06-07-2014, 05:26 PM
GlenL
GlenL's Avatar
I sympathize with you. I've had two cars that had aftermarket alarm systems along with elaborate stereo installations. I was able to remove all of it by carefully reading the wiring diagrams and slowly figuring out what they had done.
30A is a lot of juice. I'll uess it was for an alarm system and fed, from the control box, back to the rest of the car. Maybe it splices back into the power feed to the fuse panel.
If you look at the new harness those two small ring connections should be different sizes. The connections to the starter have two (OK, three) different sizes for the connections.
Old 06-07-2014, 05:47 PM
Alan
Electron Wrangler
Alan's Avatar
Can you show a picture of the back of the relay socket where the wire go in? - it's odd looking.
Two possible purposes:
1) Starter disable for an alarm system
2) Local relay for starter solenoid (you have a starter relay already on the CE panel)
In case 1 you can just strip it all out, in case 2 - I'd have to presume there was some issue with the stock starter relay that explains why this was added... in any case that should still be fixable... I'd check if the CE relay has been bypassed somehow though...
Alan
Old 06-07-2014, 05:50 PM
Five-8
Five-8's Avatar
Thanks Glen,
There are NO other splices/connections...this is all there is... meaning that it doesn't pick up any other connections between the top picture and the bottom picture.
Old 06-07-2014, 05:57 PM
Five-8
Five-8's Avatar
Alan is this what you need to see?
Will check the CE panel.
Old 06-07-2014, 06:01 PM
Alan
Electron Wrangler
Alan's Avatar
Can you show the back where the wires enter the socket - so I can see what goes to what terminal - so far in both these pictures it looks like a relay with only one side of the coil connected...
Can you also take the relay out and show the terminal end - it seems to be an oddball dual 87 relay in ~Bosch pinout
Alan
Old 06-07-2014, 06:27 PM
Five-8
Five-8's Avatar
Alan
Apologies in advance if i am not understanding.
So in the pic.
Blue at 12 o'clock,Red at 3 o'clock,yellow(ground) at 6 o'clock, black in the center, nothing at 9 oclock
Old 06-07-2014, 07:06 PM
Alan
Electron Wrangler
Alan's Avatar
OK I can't read any terminal ID's next to the pins - can you?
If they are there - can you describe them with the perpendicular terminal to the top.
Alan
Old 06-07-2014, 07:25 PM
GlenL
GlenL's Avatar
Oh...
That could be a starter boost relay. On later cars the solenoid needed more current when hot, or the ignition didn't give enough, and people ran an extra set of wires.
Old 06-07-2014, 09:23 PM
Five-8
Five-8's Avatar
Alan
12 o'clock is marked 85,3 o'clock is marked 30, 6'oclock is marked 86, 9'oclock is marked 87, center is marked 87
Old 06-07-2014, 11:10 PM
Alan
Electron Wrangler
Alan's Avatar
OK from what you describe this is case 2 a local starter relay..
You should not need this - investigate the CE panel starter relay
Alan
Old 06-07-2014, 11:22 PM
MainePorsche
MainePorsche's Avatar
Alan
Why would an aftermarket alarm install go through all this trouble to add a relay along with the wiring to the starter (actually looks like reasonable quality) and bypass the CE starter relay ? You'd think their controller would tie in to the starter relay for shut down.
I don't think this is aftermarket alarm stuff as it looks like it is a mechanic in over his head with starter electrical issues.
Old 06-07-2014, 11:32 PM
GlenL
GlenL's Avatar
Got time now to search for this.
I believe that you've got the problem and fix in this thread:
https://rennlist.com/forums/928-foru...it-coming.html
Check it out but if it's boosting current to the solenoid then I'd leave it in there.
Old 06-08-2014, 04:14 AM
Alan
Electron Wrangler
Alan's Avatar
What I said was it was some kind of bandaid to replace/supplement the stock starter relay (let's stay with the plot here...).
It may indicate some issues and also possible butchery to the stock starter relay.. so worth checking there for modifications...
Alan
Quick Reply: The last of the PO's aftermarket wiring...wired to starter
