How to tell if it's an 86.5
Last four digits of the VIN higher than 1000.
I think that only applies to some countries so it depends on where you are from, fairly sure all Australian 1986 are 86.5. Brake calipers will tell you unless they have been upgraded by PO.
My euro vin is 0146 and was brought over from Germany and has 86.5 features - brakes, dual exhaust, smaller battery box to fit exhaust.
From Wiki......
1986
Model designation: 928 S / 928 S2 (UK)
1986
- Engine displacement: 4.7 L (286 CID) / 5.0 L (302 CID) (North America, optional ROW)
- Valves: Two per cylinder (four for North America, optional ROW)
- Power: 310 PS (306 hp, 228 kW) (worldwide) / 292 PS (288 hp, 215 kW) (for North America)
- Changes:
- Lowered 9.3:1 compression ratio four-valve engine optional for some ROW markets along with catalytic converter, standard in Australia. Compression change was done with different shape piston tops.
- "S4" suspension package and Brembo brakes for 1986 models (from VIN 1001 and November 1985 onwards in North America). No U.S. models made with VIN ending between 0938 and 1000 due to parts change.
- ABS brakes became standard for all markets during model year production.
