928 Forum 1978-1995
Sponsored by: 928 Specialists
Flatbedding a 928
Old 03-31-2014, 03:39 PM
86gtvert
86gtvert's Avatar
Another interesting point regarding U-Haul. They would not rent a car trailer to me after their series of 20 questions, they informed me that the 928 would not "fit" because it sat too low.
Old 03-31-2014, 03:47 PM
James Bailey
James Bailey's Avatar
Correct they know it IS too low...and the ramp angle too steep. Plus they have to be worried about **** Porsche a$$holes.....and liability.
Old 03-31-2014, 05:55 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I just picked up my 928 this past weekend and also had to travel about 500 miles. I used a 18' dove tail trailer that I had welded d-rings on each corner of the deck. I hooked straps to the factory tow hooks under the front facia and looped the rear straps around the trailing arms, hooking each straps other end to the D-rings. I centered the car over the tandem axles and it pulled great behind my F150. (ok, the mountains were not alot of fun but the weight distribution and security of the car were spot on)
More than a few folks, particularly tow truck drivers, have " looped the rear straps around the trailing arms", and ended up trashing the lower arms when the transverse 'blades' got bent. For those playing at home or reading this for later reference, the only safe way this works is to use a couple short choker straps around the tube part, then pull down and to the rear under the hub carrier.
Old 04-01-2014, 04:31 PM
Drewster67
Drewster67's Avatar
I jacked up the tongue while it was still hooked to the truck to offer a less harsh angle going up.
Yes - I finally got rid of that bitch of a trailer - plus the ramps were like 60 pound each ....
Quick Reply: Flatbedding a 928
