928 Forum 1978-1995
Sponsored by: 928 Specialists
928 racer challenge..kibort vs the world.. March 22-23 Thunderhill
Old 03-17-2014, 01:22 AM
  #61
mark kibort
mark kibort's Avatar
Originally Posted by GlenL
I used to do that. I'd downshift hard in the braking zone and hold the revs up to be at max power at the apex. Now I downshift after turn-in, or trailbraking, and roll on smoothly.
There a spread between babying it, working it hard, and beating it. Beating the car is fun and exciting but it's not faster.
agreed.... there is a reason why its not faster, and its because you really want to have a shift well after the exit birm, not in or before it. before and after a apex usually, you are at a 0 acceleration situation. because of this, having the engine at high rpm , can hurt the engine and hurt your ability to put down the power through the exit.
Originally Posted by justaguy
My point being in my previous post not that I am the worlds greatest driver but I do have a pretty good idea about what is fast and what is not.
I love 928s as much or more than anyone, I own 7 of them but any one who thinks a stock 928 oiling system is a good choice for a track/ race car is delusional.
Hmmmm you see what I have done with mine and its over many many years now..... so to not be interested or thinking what im doing is a one off or lucky, is being in denial.
Old 03-17-2014, 03:04 PM
  #62
justaguy
justaguy's Avatar
Mark
What you're doing works for you but no one else has been able to reproduce your results. NOBODY!
As I've said before I'm definitely not the worlds greatest driver and I'm not egotistical enough to believe I have nothing left to learn but I'm pretty sure I'm not the only guy to down shift and throttle through a corner.
Old 03-17-2014, 04:04 PM
  #63
Drewster67
Drewster67's Avatar
Drewester
I would like to state for the record that I would never intentionally over rev or otherwise maliciously damage a 928 engine or any other engine for that matter. I drive them they break that's just the way it is.
Sean
Never took your comment in a negative manner - all good my friend.
Old 03-17-2014, 04:08 PM
  #64
Drewster67
Drewster67's Avatar
Originally Posted by IcemanG17
Drewster....after watching your video with the "slush" box....I have lots of suggestions to improve its performance on track.... I can hear lots of parts where you lift, then it upshifts...which sucks...then you must downshift again...
I think you are running a 4 speed like I raced for YEARS in the estate....what we did to make the "ghetto-quential" as we called it was this
Disconnect kickdown and bowden cable....then start in 2.....it will start in 1st gear off the line....quickly bump to 3 then back to 2.....this will hold 2nd FOREVER....until you shift to 3rd....then when you want 2nd you just slap it back to 2.....poor mans sequential for sure....works perfect... I also would adjust your vacuum modulator a bit....increase it (turn clockwise) 1/4 rotation...it will firm up shifts and shift speed quite a bit...
It will only shift gears when you move the lever....always start in 2....if you start in D it will almost instantly shift to 4....and lug like crazy....
I thought about it many many times but in the end - its not really going to add any time for me. Most of the AZ tracks I run are 2/3 gear tracks - never used 4th and doubt I ever will unless we have a mile long straight to use. I leave grid in first - go to second then up to third then back down to second for most of the corners. That's it - 2/3 - 3/2 all the way around.
BTW - did you ever sell that built LS motor??
Old 03-17-2014, 05:06 PM
  #65
IcemanG17
IcemanG17's Avatar
Thats how we raced the estate....everything is 2-3-2 over and over again...since 3 is a 140mph gear!!!!
Still got the LS2....should be about 520hp-475ftlbs pm or email if you are interested
Old 03-17-2014, 06:04 PM
  #66
Drewster67
Drewster67's Avatar
Ill get back to you on the LS2 motor - Ill know more this Thursday afternoon.
Quick Reply: 928 racer challenge..kibort vs the world.. March 22-23 Thunderhill
