Brake rotor, caliper upgrade question
Hi,
Planning to upgrade my stock brake rotors and calipers on my 91 GT and 88 S4.
Both will have 17'', Cup 2 GTS wheels. Can I use any of the Porsche 911 rotor+ calipers with these wheels.
Thanks.
Evren
Thanks.
Evren
Stick with the 928 rotors, the 911 rotors don't have the correct offset.
Any 911 4 piston calipers will fit if they are from the 993 back as far as I know.
Any of the calipers including the big reds/blacks will fit under the 17 inch rims.
Thanks,
Just to understand your advise; if the rotor diameter will not increase , do you think changing the calipers might improve braking?
I have my stock rotors and calipers, now that the wheels will increase from 16inches to 17, I was thinking, can I use this extra space to improve my brakes.
In order to see an upgrade in braking you will need to dissipate heat quicker, which means a bigger rotor.
So you will need bigger rotors from a GTS or a better pad compound to see better results with the better brakes.
I think a few people run the rotors off of a Ferrari F50 on their 928s, they are even bigger than the GTS rotors The 330 Cayenne rotors are another good option to run on a S4 as they are cheap.
Running 911 brakes wont provide any improvement over 928 S4 brakes unless they are the big reds or blacks.
There was a thread on that at some point, I don't know the results of it though.
However you would need 18 inch rims to fit the massive 6 piston calipers under them and then it would be a lot more difficult to find a good pad to use...
Nice going Evren! While some of us find it deifficult enough to fix one car, you have 2 at the same time in apparantly the same status of ground-up rebuild. Must be more efficient this way. Not mixing up the parts would be my headache! Do you use a strickt divider leftcar / right car?
