Oil pan removal??
#31
Under the Lift
Stan: Ah, I get it now, working the gasket around the outside of the pan. I suspect that would be hard to do with the original cork gasket, but easy enough with the aftermarket rubber one.
#33
#35
Chronic Tool Dropper
Using the stacked 4x4 method is cool, but... you get to raise the engine to its final height using a jack and blocks under the oil pan. Be sure to remove the complete air cleaner housing before you raise anything. Wedges are needed to support the transmission, so the weight transferred by lifting the front of the engine doesn't collapse them.
Clean everything first. Clean everything again. Disassemble, and clean everything. You'll still get dirty under there.
#36
Can you expand on that...i'm not clear what you mean. How do I do this?
#37
#38
The additional weight transfer by lifting from the front of the engine vs the supporting via the middle is negligible. Think around 20# no enough to make much of a difference.
#39
Dwayne's Motor Mount Writeup:
http://dwaynesgarage.norcal928.org/MotorMounts.htm
And I fully agree that it's more than a little messy doing this job.
#40
Wonder where Dwayne is. Hasn't posted since August
