Lazy brain Wheel Size Fitment
Too lazy to search, find, and use the wheel calculator thingy...
Will 993 wide body wheels...
18x9 et 50 front
18x10.5 et 44 rear
fit on a GTS?
18x9 et 50 front
18x10.5 et 44 rear
fit on a GTS?
AO's calculator says no on the front. It's based on a GT, so can't apply it to the rears. That said, I'm pretty sure those will fit. I'm sure someone else will chime in with more definitive word.
BTW - I'm running 17x9 on the front with no rubbing, but mine have an ET70. That puts mine 20MM further in, about .78"
Administrator - "Tyson"
They will stick out up front a bit. Far from ideal when stock is et65 - et70
Here is what my 18x8 et56 wheels look like up front.
A 9" et50 wheel will stick out 18.7mm further out. Almost a 3/4".....
Fenders are aluminum, not quite as easy. Possible yes, but not as easy as if they were steel. I've watched people heat and stretch 928 front fenders only to have them go back to "stock" as they cool off.
Aluminum has an annoying memory that way....... Again, not saying it's impossible, but is it worth it??
On top of that, even if you do stretch the fender enough to cover a 3/4" - 1" overhang, the overall contour could still be an issue. Hitting a bump while turning will still have a darn good chance of hitting the underside and doing damage.
On a track rat, I could see doing this. On the OP GTS???? Praise the Lord......
Not to mention why take all the effort to fit wheels that will have a negative effect on the handing of the car?
Just buy wheels with the proper offset or at least something relatively close.
As for Kibort's idea (on a street car) might as well just order generic plastic fender flair add-ons from JC Whitney while you are at it.
I did it on my 86.. Granted I just roller the lip and fender a little bit. The biggest issue I found was for some reason on the aluminum fenders the paint doesn't stitch as well as it does on the steel. I stretched the fenders on my Skyline quite a bit and never had an issue. But it always seems to want to lift more on the aluminum a lot more.
The rears will fit but not with GTS spacers assuming you intend to fit rubber proportionate to the wheel size. Then you have the problem with studs that are too long for closed nuts etc.
On the front, the fit would be marginal with a 225 section but why fit a 9 inch wheel to mount a 225 which may not even be wide enough for a 225 section and that before you consider the NSR or more to the point, the total lack of it at ET50.
Fred
Fred
