928 Forum 1978-1995
Sponsored by: 928 Specialists
Updated Single Page Central Electric Panel Relay, Fuse & Plug Details (All Years)
Old 04-02-2014, 09:29 PM
  #151
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by Fogey1
It's more than i can do AND I missed it in the post. Double DOH!!!
Ahh No!
I actually added it after you reminded me to do so...
And the links are easy - copy the URL you want to the clipboard, create your post text, highlight whatever you want to be the link text, click the icon with the earth and a chain link and past in your URL - Done!
Pretty easy - you can do it for sure!
Alan
Old 04-08-2014, 01:12 PM
  #152
heliflyer
heliflyer's Avatar
Alan
Sorry for the delay - here is my 1986 ROW panel. VIN WP0ZZZ92ZGS841887
Panel part no 928.610.105.13
There are a few relay differences that I have marked in blue on your pdf file for 1986 cars - file attached.
There are also strangely some fuse locations that do not have an input wire (marked with red triangles) or an output wire (marked with blue triangles) although some of the items - lights and central locking are present and working - very baffling!!
I have also attached two photos of the rear of the panel covering fuse locations 1-25 and 26 - 45.
Regards
Jay
File Type: pdf
Old 04-08-2014, 02:10 PM
  #153
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by heliflyer
...There are also strangely some fuse locations that do not have an input wire (marked with red triangles) or an output wire (marked with blue triangles) although some of the items - lights and central locking are present and working - very baffling!!...
Regards
Jay
Jay thanks. I have had lots else to do in March and made little progress here. It was also obvious that being finished with evaluations by early march was not possible for many owners due to weather - so I'll be trying to wrap this up soon (at least the feedback stage - anyway).
The fuseholders with no output connections are for unused or unpopulated options (e.g. telephone), no point in having fuses installed there.
The apparent lack of inputs is deceiving - those inputs are connected to adjacent fuse inputs within the fuseholder block (e.g. you can't see it no matter how hard you look)...
Alan
Old 04-08-2014, 02:13 PM
  #154
heliflyer
heliflyer's Avatar
Ahhh..... That explains yet another Porsche mystery !!!
Old 04-10-2014, 02:38 PM
  #155
Leon Speed
Leon Speed's Avatar
I still have to do the ROW '89..haven't forgotten, just swamped with work lately.
Old 04-10-2014, 05:29 PM
  #156
G8RB8
G8RB8's Avatar
Thanks Alan!
Old 06-21-2014, 11:32 PM
  #157
yaskota
yaskota's Avatar
Originally Posted by yaskota
Claiming USA '84...
Model: 1984 Porsche 928 S (US) L-Jet
VIN: WP0JB0929ES860929
Auto Manufactured: 11/1983
CE Panel Info:
928.610.105.07
89-6194
Made in W. Germany
(Better late than never...)
Alan's chart was spot on & better than any other resource I could find in the prep stage of refreshing my CE Panel refresh- and equal in value to the Porsche Owner's Manual for my 1984 928 S (US) L-Jet... one change, noted in my documentation, #5 fuse installed was 8A and is now 16A.
My documentation & Alan's PDF I used in addition to Manual (attached) + picture of panel (before plugs re-attached).
https://www.dropbox.com/s/tf49q542yb...%20Refresh.rtf
https://www.dropbox.com/s/1n0f8u5lhx...lay%201984.pdf
Old 06-21-2014, 11:40 PM
  #158
yaskota
yaskota's Avatar
Oh... I should also add that originally (as in upon taking possession of my car), I noticed a number of VW relays were installed- and their related devices not working properly.
Taking a closer look- which I'm sure many have done before- if a relay's external wiring diagram has any meaning (which it should) it may explain why so many of the PO's (VW) relays were going bad so often...
(VW on top, Porsche on bottom... that extra line between 85 & 86 is a resistor, right?)
Old 06-22-2014, 03:53 AM
  #159
Fogey1
Fogey1's Avatar
... Taking a closer look ... if a relay's external wiring diagram has any meaning ... it may explain why so many of the PO's (VW) relays were going bad so often...
Nice catch, yaskota. I'm guessing you're right. Thanks.
will
Old 06-22-2014, 07:11 AM
  #160
Landseer
Landseer's Avatar
Alan,
Referencing post 117, your (very nice!) relay chart showing what positions are occupied by MY.
Please consider one change, assuming you haven't already captured it in a later version somewhere.
MY 1984, Relay position XI.
Chart shows "not used in this year"
False.
Indeed used in 1984 -- for antilock brakes.
This was optional for USA market, but I think it was standard equipment for ROW.
Verifications --- a) Workshop manual Current Flow Diagram #97-191 for 84 ROW b) Workshop manual Current Flow Diagram #97-193 for 84 USA/Japan c) CE panel, my Euro 84 car.
From the USA version of the diagram for 84----
Old 06-23-2014, 04:48 AM
  #161
yaskota
yaskota's Avatar
Originally Posted by Landseer
...MY 1984, Relay position XI.
False.
Adding to that... my '84 (US) does not have antiblock brakes, and relay is empty. However (I think courtesy Mr Edwards), the option code is:
M593
Antiblock System (Bosch ABS) # Vehicles Produced: 3567
Old 10-21-2014, 08:24 PM
  #162
Ducman82
Ducman82's Avatar
any update to this massive project?
Old 12-23-2014, 06:00 PM
  #163
Daniel5691
Daniel5691's Avatar
Sir:
Again, thank you.
What a wonderful resource.
Dan
Old 05-10-2015, 03:44 PM
  #164
hb4
hb4's Avatar
Hi, Alan
Had an occasion to question the fuse assignments on my car, and I remembered this thread and reviewed it.
It doesn't appear you've had feedback on '89, so I checked your '89 US diagram against my '89 CE panel cards and found everything as your diagram indicates except Relay 19 Roman on your diagram is 'XIX' rather than 'IXX'.
The panel card has part number 928.610.023.03 at the bottom and a logo and 928.610.211.09 with the words Siebdruck Folz (silkscreen Folz) at the top; I'm guessing the number at the bottom is the panel number. If you need confirmation, I'll take a look a the panel itself. I'm curious whether I have the fuse puller so I can find that out as well.
Old 05-11-2015, 12:46 AM
  #165
F4GIB
F4GIB's Avatar
Default daytime driving lights
On the 1992-1995 cars, relay #6 is light purple (I got it from a Canadian dealer, forget number) and controls the daylight driving lights.
Quick Reply: Updated Single Page Central Electric Panel Relay, Fuse & Plug Details (All Years)
