Awesome and/or crazy turbo project. You pick.
#121
I designed the carrier to be easily removable. Why? I have no idea other than, again, I didn't want to drill holes through to the inside and pass screws through. It's located by the pieces of aluminum that it fits to like a puzzle. The pins sticking out just hold it down with wavy washers, then stainless washers, and finally the cotter keys.
I feel like I should own a portion of Mcmaster-Carr now.
#123
I tried to figure out how to make the rods that join all the bits of linkage. I will have three in total. Aluminum might have expansion issues (I don't really know), steel seemed boring and heavy, so I finally gave in to something a little more elegant. I ordered carbon fiber tubes and aluminum ferrules that where pre-threaded on the inside to match the heim joints. Some quick work on the lathe on both ends and they fit like a glove, with the outside just bigger than the O.D. of the carbon tube. I'm getting the inserts anodized along with the aluminum throttle arm and possibly a few other pieces at the same time (Wing uprights? Intercooler? Who knows). After some research I plan to glue the pieces together with Loctite 680 and some fine glass beads from the sandblaster mixed in. The glass beads are a nifty tip from an SAE forum about retaining the machined ends in carbon suspension members. I made a couple extra inserts and have extra tube to do destructive testing with.
#126
Thanks guys. This should make sense out of what I have been rambling. The bent up pieces of welding rod are temporary to show how it joins. The real ones will go on when the anodizing is done.
#128
Hey all. In the last year I've met a new girl that I'm likely about to be engaged to. My father has passed way from Parkinson's disease, which before and after put a particularly hard load on my mom. The shop has been very busy. I haven't lost any enthusiasm about my project and have accumulated a decent bit more parts towards the project. A few things could be posted now, but I'll be back with a real update soon.
#130
You should keep updating the thread as parts come in. This despite the obvious risk that a bald guy will drive here in a corvette and start educating the public about how this has all been done before, others are making 1200hp, how nitrous oxide and E85 is widely available, etc.
