Value of 70k GTS crank
Seriously, you think a warranty on a crank is better than having standard sized bearings and meeting original specs with a used crank?
Surely all the cranks returned to Porsche for "refurbishing" are the result of some catastrophic engine failure sufficient to damage the original crank. I don't know why people would even consider them as part of an engine rebuilding.
How do I know the used crank is straight?
How do I know the new glyco bearings that I would have to buy are on spec?
How do I know the used crank has no micro cracks?
What is my comeback to you?
Oh, just because you say so...
Knowing how **** Porsche is about standing behind a product, I think I would take my chances. In the meantime, if you feel better about using a 2nd hand one, go ahead. That's what makes the World go round - difference of opinion...
If you buy a used crank, you will need to have it measured and possibly turned down. A use crank that is guaranteed to be within the spec is obviously worth a lot more than a used crank that is not guaranteed to be within spec. My personal opinion is that it makes no difference whether an induction hardened crank is undersized by .25mm or not. What matters wheter the crank is reliably within its spec.
Plus the Porsche warranty is IF the crank fails......you get another crank PERIOD ! no rebuild costs, no rods, pistons, or block. You have a replacement crank with no place to use it.......that does not give me a warm fuzzy feeling
Basic Site Sponsor
Basic Site Sponsor
My "rule" of thumb is to never use a turned crankshaft...only standard/standard cranks, for my engines.
I'd expect that a used 928 crank, worth selling, would need a micro polish in the worst case. I'd certainly make this a condition on any purchase....
The day comes that I can't measure a crank to see if it is straight or measure it to be the correct size and match it to the correct bearings, is the day I will hang it up.
Well know local crank maker uses Chinese suppliers to furnish low cost "stroker" cranks for popular US engines....some of the units fail final inspection after being imported.....So they turn them down undersized and sell them at a discount to shops which sell completed stroker motors knowing that the ultimate customer is NOT going to tear down his "new" engine to check to see if it is a std std crank..... Trust me on this one....
Let's agree to disagree on this one and just put it to bed...
