928 Forum 1978-1995
Sponsored by: 928 Specialists
Leeroy's clutch.... Ouch
Old 01-21-2014, 10:32 AM
Jerry Feather
Jerry Feather's Avatar
Do you need some door hinge shims? They are free for those in need of door gap adjustment.
Old 01-21-2014, 10:56 AM
BC
BC's Avatar
Thanks Jerry. I am not sure at this time. I personally think the handle is simply broken. The cast piece that connects to the outside handle.
Old 01-21-2014, 03:51 PM
kaptnknemo
Bumbling Neophyte
kaptnknemo's Avatar
I have a complete driver's door from a parts car and will donate a handle(+) to Leeroy if y'all want.
Old 01-21-2014, 03:55 PM
BC
BC's Avatar
Thank you. I will find out what is needed if anything and return here or contact you.
Just gotta get some time on it again.
Old 01-21-2014, 04:06 PM
Randy V
Randy V's Avatar
This poor car has been beaten like a red-headed stepchild.
Better to spend the $40 and get a new assembly than install a used one that is on the verge of breaking.
Old 01-21-2014, 04:25 PM
BC
BC's Avatar
It has been taken care of properly for several years now. Its a 34 year old car, and lives a much better life than many other 928s this old.
Old 01-21-2014, 04:31 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,247 Likes on 1,243 Posts
Thanks for taking the time to Fix the clutch in Leroy Brendan.
FWIW I would only install a new door handle hinge assembly,
If using a used part you wouldnt be the first to tell of having to do the job twice.
Also then make sure to lubricate the mechanism inside the door prior to putting it back together.
Old 01-21-2014, 05:10 PM
BC
BC's Avatar
If using a used part you wouldn't be the first to tell of having to do the job twice.
I just can't shake the feeling that you don't know who/don't care who you are talking to when you give advice. "Make sure you lubricate the mechanism"
I'm not some random guy asking how to change the oil on yahoo answers. Do you see the join date on my posts? I don't know everything, but I sure as hell know there is something askew with you and your awareness of who you are responding to when you post on here.
Just strange. Really Really strange. Lubricate the mechanism. Yeah, and I'll be sure to use the metric sockets too.
I am sure someone will rag me on this but its a gut feeling for me. And I stick with those.
Old 01-21-2014, 05:48 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Brendan sorry if you feel slighted thats not my intention.
a simple thanks would leave you with a smile on your face,
try it in front of a mirror.
Anyhow you would be amazed at all of the other people that might be following along here,
and little tidbits of info can make someone else`s job easier.
Old 01-21-2014, 06:48 PM
Captain_Slow
Captain_Slow's Avatar
Stan answers anyone's questions in a way that is intended to enter the huge body of knowledge that will be searched by others. I go to Dwayne and a few other members for DIY guides. But when I do a search I am amazed how often Stan's posts are the ones that provide the answers.
Last edited by Captain_Slow; 01-21-2014 at 09:36 PM. Reason: Trimming off topic content...defending a valuable 928 expert
Old 01-21-2014, 09:09 PM
karl ruiter
karl ruiter's Avatar
Actually....I have done the handle hinge replacement job four or five times (different doors, I think), and I have never particularly worried about lubrication of the hinge assembly. Perhaps the actual latch mechanism? But in that case it is usually as much a case of washing the dust, leaves, primer dust etc that accumulates in a mechanism like that over 30 years than actual lubrication. I think the best course if it looks messy is to pull the whole mechanism out and take to the solvent tank for a real cleaning.
Old 01-21-2014, 09:11 PM
BC
BC's Avatar
As I said "Lubricate the mechanism" - very strange.
Old 01-24-2014, 04:14 PM
BC
BC's Avatar
Something else Let go on Leeroy today. I have to stop saying how reliable this car is. Its been towed a few times now.
The Proper torque was used on the collar between the TT shaft and the short shaft. If that is what let loose that means that the torque wasn't real, the welds came apart on the collar blocks, etc.
If that is NOT what let loose, then it may be the transmission. Which would be very bad.
I am hoping its just a matter of old pieces. I have other collars and other short shafts. Of course that means removing the clutch again. ****.
Old 01-25-2014, 06:32 PM
Randy V
Randy V's Avatar
Did you remember to lubricate the mechanism when you re-installed it?
Old 01-25-2014, 07:21 PM
BC
BC's Avatar
Yes, lol. And the "items" were installed properly as well.
Quick Reply: Leeroy's clutch.... Ouch
