Official 928 VIN & Option check request thread
#2523
Archive Gatekeeper
WP0JB0929JS861251
1988
C02
M28.42- engine serial # range 81J 00001 >05000
A28.12- A 2812 2J 10001>20000 (The 2J indicates LSD!)
M018- Sport steering wheel with elevated hub 30mm
M139- Adjustable Seat Heating - Left
M220- Limited Slip Differential, 40%
M340- Seat heating - Right
M418- Protective side mouldings
M474- 1986.5-up Boge GZ twin-pipe gas shock absorbers, Fire Red (RAL 3000 paint)
M494- 87-88 Additional amp Blaupunkt BPA420
I513- Lumbar support - right seat
M533- Alarm
I538- Right seat with positrol and lumbar
M570- High output air conditioner
I586- Lumbar support - left seat
M650- Sunroof
I691- CD-Player "CD-2" with radio (Possibly maybe a CD-1 since it's an '88? Dunno. Is there a radio operation manual in the glovebox?
I980- Seat cover - draped leather
1988
C02
M533- Alarm
M650- Sunroof
#2524
Archive Gatekeeper
WP0JB092XKS861146
1989
C02
M28.42- engine serial # range 81K 05001>10000
A28.16 - transmission serial # range A 2816 2K 00001>20000 (2K = LSD)
I158- Blaupunkt Reno SQR48, 1989 only (?)
I195- Prepared for cellular telephone (Motorola)
M650- Sunroof
1989
C02
M650- Sunroof
#2525
WP0JB0929JS861251
1988
C02
M533- Alarm
M650- Sunroof
1988
C02
M533- Alarm
M650- Sunroof
#2527
Archive Gatekeeper
Not much info on this one-
92A0821311
1980
C00 - German market
000000 - No engine code, but should be an M28.11 serial # range 820 0001>1000
G00000- No transmission model type specified, but should be a G28.05, serial # range 11 05001>09999
M197 - 88Ah battery
That's the only option listed. Depending on the interior materials you have the lightest Euro S one could have.
92A0821311
1980
C00 - German market
M197 - 88Ah battery
#2529
Archive Gatekeeper
WP0JB0924JS861271
1988
C02 - 49 states US model
M28.42- engine serial # range 81J 05001>10000
A28.12- trans serial # range A 2812 2J 10001>20000
I158- Blaupunkt Reno SQR46
M570- Rear A/C
M650- Sunroof
1988
M570- Rear A/C
M650- Sunroof
#2531
From the VIN (wp0zzz92zBs84...)This is a Euro 1981 928 S (300hp) and from the G00000 must be a manual.
So m28/11 engine and G28/05 gearbox, certainly.
I'm also curious to see pictures of the car.
A base 1981 French S should be without sunroof and right mirror but with side stripes.
Do you have any document in French?
#2533
Whoever said that it was a "competition package" was wrong.
That was a US only option, mostly cosmetic, that mimicked the look of the Euro S.
That is a Euro S.
Fender turn signals (behind the wheel), cheap add on corner markers, rear fog, headlight adjuster **** (next to the handbrake), K-Jet motor, no rear 'bumperettes".
If it was French delivered, it would have come with yellow fog and driving lights. Those may or may not have been changed when it was brought into the US. (are you in the US? Can't read the state on the plate)
And there won't be a "sticker" on the motor. It's stamped into the top of the block, front left.
The sticker will be under the carpet in back (if it's still there). It will list the VIN, along with the motor type, trans type and option codes.
That is a Euro S.
