Does drain hole in fuel filler neck drain into tank?
Sorry if this is obvious, but I'm adding some fuel stabilizer and wondering if the bottle neck doesn't go far enough to push to actual fuel flap open am I right in thinking it will get to the fuel by way of the drain hole in the fuel filler neck?
Curious, what stop fuel from leaking out this hole?
I'm thinking when my tank is filled up in Robinson, TN with all the twisties enroute to SITM, that's what causes my right rear fender to be fuel stained. I have another tank in the attic waiting to install, just haven't got around to it since it only happens once a year.
Anyone else ever have fuel leak on hard cornering after filling up?
Not only the fender,
I know the hole in the outer rubber gasket drains, but I'm talking about the one in the metal fuel neck. Does that drain into the tank.
I ask because I have already put stuff that drained into there, so want to be sure whether or not it made it to the tank.
To be clear, here is a shot of the neck with the two holes. I'm asking about the upper one just outside the fuel tank flap.
