Air or Ground storage!
Next question since the consensus is storing the car off the ground - should you remove the wheels to reduce the weight load on the hanging suspension? I have heard that long periods in the air can wreck the shocks. Not sure if that is a real issue.
If you are not driving it through the winter with my last suggestion store it on the ground and pump tires up all around to 55pounds to prevent flat spotting and fill gas tank to the brim with race gas. (cam 2 etc). Fresh oil also. Stabilizer for added protection added when your at the station topping off and drive home. If you store it in the air then the shock shafts can get pitting and ruin the seals once driven. But I have storred collectibles for 30 years now so what do I know
Get a 4 post lift and store it in the air on it's wheels.
Better yet, on a 4 post lift, in the air, with blocks under the suspension so weight is on suspension but not wheels.
Ahhh. "Fond" memories of waiting with flashlight and .45, baiting rats in our MacNamara bunker at Con Thien.
12 ga. does seem like overkill when a .410 might do it. And that 00 buck rattles around in an enclosed space.
"it's a romantic night with my 12 gauge, a case of beer, a flashlight and my Neil Young collection!"
Okay.. I did embellish a little bit. I'll try again:
A mouse trap, a white wine spritzer, 2 candles and my "Whams Greatest Hits" album.
If you can get the rear suspension "parked for the season" in a normal postion you will be much better off.
While its up now..go have a look., you will see what I mean
