Continuation of the fuel rail thread
#106
As I have said before - when the feeder lines are not restricted (both the in and the out) then the pressure wave produced by the batch firing have more fluid to dampen them, and are allowed to travel greater distances before being reflected (similar to the Helmholtz effect). The pressure wave will travel to the next obstruction or significant restriction and be reflected back. This could be the fuel pressure regulator on the return end and as far forward as the fuel pump on the supply end - depending on how the system is plumbed.
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
#107
Sounds simple, get another stock fuel pressure regulator, replumb the rear of the fuel rails for two stock regulator, and get/install 60 lb-hr injectors. Probably should use one of Greg's U-shaped hoses just to be sure to balance the 2 sides. Then retune the car. I'll talk it over with Bill tomorrow...
At this point, we're trying to figure out how to get more air into the cylinders..., and fix the crank case breathers, and keep all the fluids cool.
Thanks,
George
#108
Talked to Bill today about this idea, and he thinks it's not worth the hassle, we're already too rich at speed during the race. Why boost the pressure if it'll just make it richer (and heat the fuel more). So we'll skip this for now. If we get to a point where we're running lean, while running over 80% duty cycle, then we'll look a delivering more fuel. At this point, we're trying to figure out how to get more air into the cylinders..., and fix the crank case breathers, and keep all the fluids cool.
I personally think it's easier to get the AFR right in all conditions, if the fuel rail pressure compensates for the manifold absolute pressure. I don't have a strong opinion on the base pressure, but I do think that one needs to get the fuel pressure regulator to compensate manifold pressure 1 for 1 to be able to take a full advantage of the benefits provided by hot-wire MAF. My preference is to do it that way.
Another thing that I don't like about aluminum "billet" fuel pressure regulators is that I suspect they are inconsistent because thermal expansion of aluminum is large. Another personal preference.
#109
Basic Site Sponsor
Basic Site Sponsor
I too would think that tuning with a regulator/regulators that allowed the pressure to rise would make tuning much easier.
However, since you have already tuned the car without this and you have reasonable fuel air mixtures, any change might be an exercise in futility. The change would also "expose" you (and Bill) to a whole bunch more tuning time.
I'd say that as long as you know that you are not running out of fuel over a long run and the pressures are fairly stable, to forget it.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#110
Developer
If I read this right, when I moved my fuel filter from in front of the fuel rails (right before the Y) to the back of the car, the distance that the pressure wave traveled was greatly increased. That could be why I don't have the oscillating fuel pressure any more. Interesting data point.
